Help with security bypass for remote start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justin144, Oct 7, 2010.
  1. Oct 7, 2010 at 11:16 AM
    justin144
    justin144 [OP] Well-Known Member
    justin
    Las Cruces, New Mexico
    2011 Taco 4X4 Dbl cab Long Bed
    Hi, I'm installing a remote start on my 2011 tacoma. I was wondering if this:
    http://www.bulldogsecurity.com/Prod...-module-for-remote-starter-installations.aspx
    is all I need to bypass the immobilizer. it is the Model 791 bypass. I guess you have to put a key in it. if this is true, where does this module go? like, can I hide it behind the dash so no one can find the key inside it? and do I have to use the key that came with my truck instead of like a copy that's made at walmart? If anyone has experience with the bypass, or wants to recommend something for me, I would appreciate it. I also saw something on that website called an interface bypass module which was about $100 dollars. what is the difference of that??
    Thanks.
  2. Oct 8, 2010 at 2:31 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    What kind of alarm do you have on the truck? Make sure it's not just a keyless entry system with a lame factory window sticker. If it is, I would go aftermarket for a better unit with more options, not to mention the module may not work with factory units.
  3. Oct 9, 2010 at 12:06 AM
    justin144
    justin
    unfortunately, I have no alarm on my truck. I'm low on cash right now so I'm just trying to do one thing at a time..
  4. Oct 9, 2010 at 12:17 AM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    If the sytem you are using requires a box for the key so that it is able to disengage the immobilizer. You will have to have a programmed chip key, which is a duplicate of your factory key. The key has a chip in in it which is programmed to your vehicle. Costs about 100 bucks a key. I am not sure what there "interface bypass" does. A plain duplicate like you can buy at Walmart will get you into your vehicle but will never start it. You can hide the box up in the dash anywhere you want to so that it is out of sight.
  5. Oct 9, 2010 at 10:09 AM
    justin144
    justin
    Ok, well luckily when I bought the truck, they gave me two keys so I think I should be good using one of those.
    Thanks so much for the help
