Help with small lift and tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RyanBelliston, Oct 13, 2011.
  1. Oct 13, 2011 at 8:39 AM
    RyanBelliston
    RyanBelliston [OP] Well-Known Member
    Diamond Bar
    2005 PreRunner
    Retrofit OEMs w/ 5000K bulbs HID 4300 Fogs Fog Light Mod LED Gauge Swap (Blue/Green/White needles) -Jerez 10'' Kenwood Subwoofer 1500W Planet Audio Amp Debadged Tinted Windows Mudflap delete AFE ProDry S intake Engage front LT 8inch Kings with 2x2 King bump stops. Strapped at 16 inches Engage 4-Link rear 16inch King coil overs strapped at 22 inches Custom Engage bumpers LED reverse lights LED license plate lights LED dome and map lights Flyzeye-Design (blue/white)
    I have an 05 dblcab sport short bed. Looking to do the Bilstein 5100 and set them to 2.5 all around. What tires would i run with this set up? 31s or 32s? Also how bad with this hurt my mpg. Im getting 18 right now on the streets (completely stock). Trying to convince my dad that it wont hurt that much :D. Since it is a Christmas present.
    Any help would be much appreciated.
    Thanks guys
  2. Oct 13, 2011 at 8:54 AM
    UpstateTRDTaco
    UpstateTRDTaco Well-Known Member
    Josh
    upstate NY
    2011 Black Tx Pro
    mods to come
    everyone on here is going to tell you to run 285s with that lift aka 33s, but i would suggest a 265/75 (32 inch in most cases)and then you wont have to cut plastics or lose alot of mpgs.
    Thats actually my set up right now and im looking at just doing 265/75/16 to avoid trouble, just gonna get an MT to make it look aggressive and wheel spacers to give it a stance like member KPT has on here.
    good luck and post pics Welcome to TW
  3. Oct 13, 2011 at 9:03 AM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    If you don't wanna hurt your mpg's too much go with 255/85/R16 about a 33 inch tire
  4. Oct 13, 2011 at 9:14 AM
    oldeskuel
    oldeskuel Well-Known Member
    WA
    05 DCSB, TRD Sport 4x4
    Stealth 6 wheels from SCS; Goodyear duratracs in 265/70/17
    Can someone post a link to the specific bilstein 5100s that everyone is using?
    I am going the same route on my rig. Gonna run 255/75/17s. TSB in the rear and billies in the front.
  5. Oct 13, 2011 at 9:26 AM
    RyanBelliston
    Diamond Bar
    2005 PreRunner
    Yes, I'll need to lift the rear as well. What can lift the rear to the same 2.5 inches? Or if I decide to go to 2.75 do I need something else to lift the rear up more? Looking to spend about 500 on bilsteins and rear lift.
  6. Oct 13, 2011 at 9:33 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
  7. Oct 13, 2011 at 9:33 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Silverado Z71
    Readylift, Truxedo, Husky Liners, Carven
    Go 2.5 with the 5100s and a 2" AAL
  8. Oct 13, 2011 at 9:34 AM
    RyanBelliston
    Diamond Bar
    2005 PreRunner
    And how bad will this kill my mpg? That's the only thing I'm worried about.
  9. Oct 13, 2011 at 9:36 AM
    97yota4wd
    Eric
    Mesa, AZ
    with 33s, 2mpg max, depending on how heavy of a tire you get
  10. Oct 13, 2011 at 9:41 AM
    RyanBelliston
    Diamond Bar
    2005 PreRunner
    Where can i buy the AALs?
  11. Oct 13, 2011 at 9:41 AM
    97yota4wd
    Eric
    Mesa, AZ
    you can go through toytec
  12. Oct 13, 2011 at 9:47 AM
    97yota4wd
    Eric
    Mesa, AZ
  13. Oct 13, 2011 at 9:48 AM
    RyanBelliston
    Diamond Bar
    2005 PreRunner
    how many AALs do i need to get the back up to level out with my front 2.5 lift with the Bilsteins?
  14. Oct 13, 2011 at 9:51 AM
    97yota4wd
    Eric
    Mesa, AZ
    just 1 each side.
