Help with some hella wiring
Discussion in 'Lighting' started by dira1987, Jul 23, 2012.
  1. Jul 23, 2012 at 2:27 PM
    dira1987
    dira1987 [OP] Well-Known Member
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    So i bought 2 hella 700s on craigslist and i am looking to hook them up. I know the lights work and everything because i hooked them straight to the battery to check them so no worries there.
    I have seen the hella wiring harness kit but i was wondering if there was another (cheaper) way to do it? I know i should use a relay and i already have a switch. Any recommendations or suggestions? Any help is great thanks!
  2. Jul 23, 2012 at 3:12 PM
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
  3. Jul 23, 2012 at 4:37 PM
    dira1987
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    Awesome! Thanks for the info. For some reason i cant order from that site though maybe its because i was on my phone.
  4. Jul 23, 2012 at 4:41 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Your best bet is to use a relay and inline fuse. Check pep boys or advance auto if they are in your area.
  5. Jul 23, 2012 at 6:56 PM
    RacerP
    Chicago
    2003 4x4
    Amazon is the cheapest for those, when I was searching...
    And it does have the right relay and inline fuse.
  6. Jul 24, 2012 at 12:53 PM
    dira1987
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    I just ordered the Dorman 85937 kit from Amazon. It cost me around 15 bucks including shipping which i think is pretty fair. I will review it next week when it arrives and i get it all hooked up. thanks for the advice!
  7. Jul 24, 2012 at 6:46 PM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    wiring up th hella kit isn't that hard, when i get some free time this week I'll do a write up for it.
  8. Jul 25, 2012 at 6:40 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Just in case anyone else reads this, Dorman is a very common automotive supplier. You should be able to walk into any auto parts store and give them the Dorman number posted above and have them order it for you. There is usually an equivilant on the shelf somewhere anyway.
  9. Jul 25, 2012 at 6:42 PM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Just make sure to use a fuse and relay.
  10. Jul 27, 2012 at 5:53 PM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    look at the last post on my build to see where the connections should be
