Help with speaker buzzing - 3rd Gen
Discussion in 'Audio & Video' started by HolyReptar, Jan 30, 2022.
  1. Jan 30, 2022 at 1:08 PM
    HolyReptar
    HolyReptar [OP] Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    I’ve got a hum coming out of my passenger side tweeter and passenger side rear door speaker when no sound is on
    3rd gen
    Jbl
    stock speakers
    Pioneer avic headunite
    Maestro controller
    Any tips, ideas, advice are welcome
    thanks
  2. Jan 30, 2022 at 1:15 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Do you have anything plugged into the aux or connected Via blue tooth? Sounds like signal feedback.
  3. Jan 30, 2022 at 1:16 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Just FYI "help" is usually reserved for being stuck and in need of recovery assistance
    Chris(NJ) and Key-Rei like this.
  4. Jan 30, 2022 at 1:32 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Make sure that you wired everything up in phase. After that, wire up the left speakers to the right channel and see if the hum is a wire problem or a HU problem.
  5. Jan 30, 2022 at 1:47 PM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Happens when stuff is plugged in or not, and connected or not
  6. Jan 30, 2022 at 1:50 PM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Why would you assume a need help post in the audio/video part of the forum is a post about recovery?
    I need help with an audio issue I’m having with the truck
  7. Jan 30, 2022 at 1:51 PM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    I thought I did, headunits been in the truck over a year and this started a week ago.
    I’ll try the speaker flip.
  8. Jan 30, 2022 at 1:53 PM
    Key-Rei
    Key
    Florida
    Bad ground?
    Unshielded wire?
    Might just be hum from the head unit to to a bad filter cap or something.
  9. Jan 30, 2022 at 2:02 PM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    bad ground to radio or truck itself?
    Never installed a filter cap. Just swapped the stock head unit out for the avic.
    Guess I’m just going to be pulling it out and testing everything :annoyed:
  10. Jan 30, 2022 at 2:16 PM
    Key-Rei
    Key
    Florida
    Yes, both stereo and truck could effect it
    And I mean the signal filters in the headunit itself could be going bad.
  11. Jan 30, 2022 at 2:19 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Doesn’t the H/U send info out to the JBL amp via Maestro?
    Check grounds on all 3 devices in signal chain, H/U, Maestro and amp.
    HolyReptar[OP] likes this.
  12. Jan 30, 2022 at 2:23 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    I'm an idiot please disregard :bananadead:
