Help with Spindle setup
Discussion in 'Suspension' started by waltonhockey17, Nov 24, 2009.
  1. Nov 24, 2009 at 8:26 PM
    waltonhockey17
    waltonhockey17 [OP] Well-Known Member
    Alex
    georgia
    08 DC Red Taco
    4" camburg spindles, billys at 0", 16" xd hoss rims, 285/75/16 xtreme mud terrains
    K so im wondering how this would look and handle?
    Front:
    billys set at .85"
    4" spindles
    stock coils
    Back:
    3" All-pro leaf pack
    and maybe upgrade to billys in the rear
    wheel and tires:
    already have 16" xd hoss's on 285 xtreme mud
    I really like the front to be a little higher. Anyone have this setup? or would know how that will sit? Any help will be much appreciated!:)
  2. Nov 24, 2009 at 8:32 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    the bilstein 5100 has 4 settings: 0, .85, 1.75, and 2.5. I am sure you are talking about the .85 setting. Yes, it would look real good if you did the .85 with spindles and 3 inch leaf pack.
    I used to have a similar setup on my old taco and it was nice looking. Though I did use 295/70/17 Nitto Terra Grapplers, so they were a little larger than your 285 setup.
  3. Nov 24, 2009 at 8:41 PM
    waltonhockey17
    Alex
    georgia
    08 DC Red Taco
    ya i would do .85, you wouldnt happen to have a pic of your truck. and was your truck level or sits a little higher in the front.
  4. Nov 24, 2009 at 9:31 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    I think that setup would look real nice. If you look in my build I have spindle lift with a coilover. It sits just a little higher up front like how your talking about.
  5. Nov 24, 2009 at 9:40 PM
    waltonhockey17
    Alex
    georgia
    08 DC Red Taco
  6. Nov 24, 2009 at 9:52 PM
    1BlkT
    Ty
    90603
    I think I have them right around 1 inch but I'll check them in the morning when there is more light.
  7. Nov 24, 2009 at 10:22 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    sounds good on what you want to do, you will need to add the 5100's in the rear if you get that leaf pack, stock shocks are too short
  8. Nov 24, 2009 at 11:25 PM
    sincitytaco
    Las Vegas
    Um....the 5100s are the same length as the stock bilsteins, so you won't gain any down travel. You are going to have to get a reservoir shock to gain travel.
  9. Nov 25, 2009 at 6:46 AM
    bajamoon
    STEVE
    Whittier
    the 5100's are 2" longer I thought, when i was getting my shocks rebuilt i was using the stock shocks as limit straps.
  10. Nov 25, 2009 at 6:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Correct on the 5100's being the same thength as OEM, but you can get extended travle coilovers to get more travle.
  11. Nov 25, 2009 at 9:55 AM
    waltonhockey17
    Alex
    georgia
    08 DC Red Taco
    so i wont have to upgrade the rear shocks? I'm going to when i get the cash but after the spindles and leaf pack ill be broke:(
  12. Nov 25, 2009 at 10:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    With 3" lift, yes, you will have to get some longer shocks.
  13. Nov 25, 2009 at 10:22 AM
    1BlkT
    Ty
    90603
  14. Nov 25, 2009 at 10:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  15. Nov 25, 2009 at 10:27 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    for the 3" leaf pack wouldnt some 5125's be better?
  16. Nov 25, 2009 at 10:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes.
  17. Nov 25, 2009 at 6:10 PM
    waltonhockey17
    Alex
    georgia
    08 DC Red Taco
    alright new plan im going with a 2" aal do i still need to upgrade shocks.
  18. Nov 29, 2009 at 10:04 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    10 PreRunner AC Sport Rally 5 Spd
    Tail gate hose clamp, Front Windows 50% tint, fog lights, 894 backup light mod, LED license & interior.
    I just learned spindle lifts exist, and that they retain factory ride, i think, and thats about all I know. Anyone wanna point me in the right direction so I can do a little research. Thanks and bump!
  19. Nov 29, 2009 at 10:13 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Check out Camburgs 4 inch spindles...those things are amazing! "06Blues" is running em on here...heres a pic of his setup :cool:
  20. Nov 29, 2009 at 10:33 PM
    bajamoon
    STEVE
    Whittier
    call camburg and total chaos, make sure to tell them you have a 4 cyl, i don't think it matters but make sure, and yes you can get the spindle and it retains stock geometry.
