Help with starting problem.
Discussion in '1st Gen. Tacomas (1995-2004)' started by willybob, May 31, 2019.
  1. May 31, 2019 at 11:42 AM
    willybob
    willybob [OP] Member
    It was suggested I post here also to get best exposure so here it is.
    Hi all. Just joined. Should have joined a long time ago. I was hoping to find help re 98 Tacoma with 2.7 losing all electrical intermittently. It runs fine but sometimes after it's parked I return to find it completely dead when I turn the key to start. No lights, no dash, no starter motor click. Nothing.The clutch interrupt is out of the picture and I bench tested the starter, which was fine. When thishappens Ifiddle with the key, the steering column lock, battery terminals, hammer to the starter, then for no known reason it comes back. Interestingly, When it does come back, my radio has lost all its programming. If anyone has any experience with this diabolical sorcery I would love to hear your thought. Thanks in advance for any ideas. Will.
  2. May 31, 2019 at 11:44 AM
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
    Welcome to TW! Could be a bad ground.
    Edit: Your radio typically will lose programming when you disconect and reconnect the battery so i'd start there. Check the main ground from the battery
    Edit again: Just noticed you said no noise from starter motor, nevermind
  3. May 31, 2019 at 11:51 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    How old is battery? Could have an intermittent bad cell in the battery.
  4. May 31, 2019 at 11:55 AM
    willybob
    It's old. I'm gonna switch with another car for a while and see what happens. I'm going to pick up a Power Prob III so if it happens again I can try to trace it.
    Thanks for your help. Will.
    Running Board Man likes this.
  5. May 31, 2019 at 2:30 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    I had this EXACT problem with my 98 4runner. Check the wiring harness that runs along the exhaust side of the motor, its clipped into the head with plastic pieces. If those plastic pieces break and the harness sags it gets real real close to the exhaust manifold and in my case it actually melted the wires and they were barely connected.
    In my case it was because the jagoff I bought it from replaced the head gasket and never reattached the harness... melted a whole bunch of stuff..
  6. May 31, 2019 at 3:40 PM
    willybob
    Thanks for that info. I'll look closer.
  7. May 31, 2019 at 3:41 PM
    willybob
    No alarm.
  8. Jun 1, 2019 at 10:39 AM
    fenmik
    fenmik Well-Known Member
    Nova Scotia, Canada
    2019 Double Cab TRD Sport.
    I had the same problem and when I checked to battery terminals they felt tight, but I guess not right enough. I tightened them down pretty tight and the problem went away. Maybe check the battery terminals and see if they are not tight enough to make a good connection.
    Abeyancer likes this.
  9. Jun 1, 2019 at 12:39 PM
    Abeyancer
    Jimmie
    PNW
    Another very good point, I had an Ford Econoline that had similar issue and even though the terminals felt tight on the ground by hand, electrically it was crap... fixed it with those metal caps you can buy from Napa to make the terminal fit tighter on the post
  10. Jun 1, 2019 at 12:46 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Clean terminals, tighten them. And check your grounds. I've seen this before with a bad engine block ground.
  11. Jun 2, 2019 at 7:41 PM
    willybob
    Thanks for the info. I had cleaned the terminal clamps an posts on both batteries I used when it first happened and the problem persisted so that's been eliminated. If it happens again I'm going to follow the fuse box test light suggestion to see what fuses are not powered.
  12. Jun 3, 2019 at 8:34 AM
    Glamisman
    Glamisman Well-Known Member
    you mentioning that the radio looses its programming, this points to a total power inturuption either a bad battery ground or a total power loss. If you have checked the grounds, there are 3 main fuses in the relay/fuse box in the engine compartment. There should be a wire, large diameter about the size of a pencil, that comes off the alternator and it goes into the relay box. This is bolted to a large metal fuse, should be 120amp fuse. look at it and check it for cracks/tightness. There are 2 other large fuses that feed the ignition switch AM1 and AM2 do the same for these. unplug and unbolt them and look at them. An electical check might not reveal a crack.
  13. Jun 3, 2019 at 8:53 AM
    willybob
    Glamisman, thank you for the info. I'll check it out. And thank you to all who have taken the time to provide suggestions .
