Help with steering knuckle 2018
Discussion in 'New Members' started by Nerfherder Likes Tacos, Apr 17, 2020.
  1. Apr 17, 2020 at 10:21 AM
    Nerfherder Likes Tacos [OP] New Member
    2018 TRD sport
    Hey I was just wondering if any knows about interchangeable parts? I have a 2018 TRD Sport. I bent the passenger side steering knuckle. The dealership wants over $1,400 to fix it so I’m gunna tackle it myself. I went to order the part and it’s around $400. Partsgeek.com has it a little cheaper but it’s not OEM. It’s Dorman. And it says that part is interchangeable all the way to 2005. So does anyone know if Dorman makes quality parts? And is it actually interchangeable with Tacomas back to 2005? Is it worth grabbing one at a junk yard? And if there is anything I should know about this removal/install?
  2. Apr 17, 2020 at 10:24 AM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Good luck, seriously. I also want to hear how you bent the knuckle, this has to be a good story. Is that all that is bent?
  3. Apr 17, 2020 at 10:26 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    buckhuntin-tacoma likes this.
  4. Apr 17, 2020 at 10:29 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Go to the Toyota parts website and check. They will cross reference back to other years. I cant say for sure, but a lot of parts are similar between 2nd and 3rd gen trucks.
  5. Apr 17, 2020 at 10:34 AM
    VirusCage
    Bruce
    Allison Park, PA
  6. Apr 17, 2020 at 11:29 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    tcjacado likes this.
  7. Apr 19, 2020 at 5:15 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! We need pics of that bent knuckle.
  8. Apr 20, 2020 at 8:59 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome!
  9. Apr 20, 2020 at 9:05 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Steering knuckles or Spindles haven't changed since 2005 to current. The part number differences you may find would probably be between a 2WD and 4WD referring to the caps installed. I have a set of third gen spindles from a 2017 if you are interested. They aren't that hard to bend and should be gusseted if not crawling through parking lots.
    Welcome to the show...
  10. May 2, 2020 at 11:00 PM
    8TaCo8
    8TaCo8 Member
    HI
    '13 4x4 Tacoma DcLb
    would the 2wd and 4wd knuckles be similar and interchangeable ? also trying to find out what the numbers stamped on the knuckles are, I know the letters are left and right but trying to find out what the numbers represent ie 36L6 and 39R1.
  11. May 3, 2020 at 3:38 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Yes, 2WD and 4WD are the same. The cap for the 2WD are the only difference and they are removable. Not sure of the stamp decode. Perhaps identifies the batch they were made with and when in case of recall or failure? Just a guess. Are you in need of a set, shoot me a PM.
  12. May 3, 2020 at 3:42 AM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Pic of bent spindle!!! Bent one on a 1st gen when the ball joint failed and it smashed the pavement at 20 mph
  13. Apr 20, 2023 at 9:35 PM
    sjm.thomson
    sjm.thomson Member
    Scott
    2019 TRD OR Cement
    3" lift / Levelled / KO2 AT
    I just bent my drivers side spindle. OP, intrigued how your Dorman Spindle worked out?
