Help With Suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by Thedoobster, May 27, 2023.
  1. May 27, 2023 at 5:30 PM
    Thedoobster
    Thedoobster [OP] Well-Known Member
    Brandon
    California
    1999 Tacoma SR5 3.4L 4x4
    3" Lift, 1.5" Wheel Spacers, 285/75r16 Tires
    I have a 1999 tacoma with an Old Man Emu 3 inch lift and an add a leaf, It's getting to where I need to replace the shocks pretty soon. The shocks I have in the front are the blue and yellow Bilsteins and I'm not sure of the ones in the rear they look like an unbranded white pair of shocks. My issue is the lift was put on the truck years before I bought it so I'm not sure of the exact measurements and what not, I want to put in Bilsteins 5100's all the way around and don't know what the measurements need to be for them to fit in good. Any help would be greatly appreciated.
  2. May 28, 2023 at 8:42 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    The 5100s for our truck only come in one length. What you have to determine is what length coil springs you want. You want your lift to come from those, so simply find coils that give you your desired lift. Then you can assemble those coil springs with 5100s or pay a local off-road shop to do that part for you.
  3. May 28, 2023 at 9:53 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Blue and Yellow Bilsteins will be the 4600 series. Silver is either 5100 or 6200(?). The front will be pretty standard 5100s for the tacoma. If they are 4600s in the rear with 3" of lift, you're either severely limited in travel, or they are "custom" length (custom in that they are generic and measured in collapsed and extended length). The rear shocks are extremely easy to remove- Just pull one off and measure them. Guessing that the standard 5100 for lifted applications will be sufficient for you though.
  4. May 29, 2023 at 6:56 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    I'm wondering how the previously installed Bilstein 4600s could work with 3" OME lift springs...wouldn't that have left very little down travel, since those are for stock springs?
