help with switchbacks please
Discussion in 'New Members' started by Fgonzo67, Jul 25, 2012.
  1. Jul 25, 2012 at 1:48 PM
    Fgonzo67
    Fgonzo67 [OP] Member
    Fernando
    Long Beach
    2011 Toyota tacoma
    •Spyder led tail lights •Retrofit headlights..worked done by EL STIG GARAGE •bulletproof fabrication grille
    so i been having these switchbacks everything works fine but i have noticed that when i press on the brakes one of them turns off and when i let go it turns back on help anyone:confused::confused::confused::confused::confused::confused:
  2. Jan 21, 2013 at 6:50 AM
    RipVanDango
    RipVanDango Active Member
    Cody
    Alaska
    '92 / 2012 TX Pro
    Leer 100XL Canopy, Home Made LED Bar, Lightforce Blitz 4300k 35W HIDs, Supertones Hella Horns, LED Bed Light,
    Did you try taking the LED out and flipping it 180 degrees?
  3. Jan 22, 2013 at 6:43 AM
    Fgonzo67
    Fernando
    Long Beach
    2011 Toyota tacoma
    Yeah I have....I even tried to switch them around..
  4. Jan 23, 2013 at 6:53 AM
    RipVanDango
    Cody
    Alaska
    '92 / 2012 TX Pro
    Is it the LED that doesn't turn on? Or is it one side if your tail lights that doesn't turn on? Also does it work normal if you put the incandesent bulbs back in? If it's the LED then it might be faulty or they sent you the wrong one. If its one side of your truck, even when you switch them, then it might be a loose wire somewhere.
  5. Jan 24, 2013 at 8:19 AM
    Fgonzo67
    Fernando
    Long Beach
    2011 Toyota tacoma
    It's the LED that doesn't turn on...now I just notice im going to have to order new ones one of them just went out..thanx again I'm going to check the wires to
