help with synthetic oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by qixer01, May 9, 2010.
  1. May 9, 2010 at 9:14 AM
    qixer01
    qixer01 [OP] Member
    mountains of NC
    95 tacoma 5spd
    k&n air filter, fuel-maxx performance chip
    i have a 95 tacoma 2.7 with 205k on it. i am thinking about switching to synthetic oil. from what i have read it will be fine to switch over. but what weight oil should i use? what was recomended from factory 5w-30 or should i go thicker? i dont know what wight is in it now. but it is time for a oil change. please let me know. i have looked and have found nothing on the weight of oil. thanks.
  2. May 9, 2010 at 9:18 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have an owners manual? That type of information is in the owners manual. Or use the SEARCH feature of this forum - blue bar towards the right. Lots of information available to you at your fingertips (and no waiting).
    Good Luck!
  3. May 9, 2010 at 9:22 AM
    qixer01
    qixer01 [OP] Member
    mountains of NC
    95 tacoma 5spd
    thanks for the info. i guess i was more asking since the motor has 205k miles on it should i go with a thicker oil than what the factory says?
  4. May 9, 2010 at 9:31 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I would stick with the dino if it was me. I just think that the engine has been on Dino the whole time and if you change it the motor may not like it. Just my .02
  5. May 9, 2010 at 9:34 AM
    qixer01
    qixer01 [OP] Member
    mountains of NC
    95 tacoma 5spd
    i have heard equally both ways... not to change it and that it would be OK to change it. has anyone with this many miles swapped to synthetic?
  6. May 9, 2010 at 9:44 AM
    Afwrestler1986
    Johnstown, NY
    All I know is that I have been running 10w-30 since i had the truck and she has 173k on her now. No problems with the dino. Aint broke, don't fix it kind of deal.
  7. May 9, 2010 at 9:47 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Stick with the same wt. and just extend your change time with the syn.
    If you stay the same time between changes then the syn. is not worth the cost.
  8. May 9, 2010 at 9:52 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    I'd stick with dino oil. You may risk exposing a leak since Synthetics tend to have more detergents in them; therefore reducing any deposits that may be keeping a seal from leaking. If you got over 200K on an engine, what's synthetic going to do for you? Reduce wear? Wear has already been done by 200K. Just stick to a regular interval change with dino and you'll be fine.
  9. May 9, 2010 at 11:35 AM
    Janster
    Jandy
    Lancaster, PA
    Not that many miles.....but I've changed to synthetics after 60K miles on a 96 tacoma and at 85K miles on a Jeep Wrangler.
    The tacoma developed 'sweating' in & around the oil pan and I actually started loosing about 1/2 quart of oil every 4,000 miles.
    The jeep never developed any leakage, but the lifters started getting loud at startups - which would eventually quiet down as it warmed up.
    It all depends on the vehicle. Synthetics tend to penetrate further/deeper and cleanse better (remove buildup).
    At 205K miles - I'd stick with dino oil. If your truck is close to having frame failure in the next year or two, then what's the point of using synthetics?
  10. May 9, 2010 at 12:19 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    04 Prerunner TRD Offroad
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    You should check out bobistheoilguy.com there is a wealth of information about all things oil. Very good information on that site.
  11. May 9, 2010 at 12:22 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Yeah, I think I spent 2 hours on their when I first found it. Its a great site.
  12. May 9, 2010 at 1:16 PM
    grant22
    grant22 Member
    Grant
    Lake Havasu
    N/A
    I had a 1992 Toyoat 4x4 Pickup. At 180k miles, I switched to synthetic. Guess what? It started leaking. Just Sayin'
  13. May 9, 2010 at 1:25 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah....Dino is probably a better option. Cleaners like Seafoam and major chemical make up changes after that many miles is risky. Leaks that have been plugged with buildup may be cleared, and you may start to hear some new noises.
    No reason to make the swap....Dino is cheaper, and you can change it more often.
  14. May 9, 2010 at 3:28 PM
    h_curtis
    h_curtis Well-Known Member
    Don't change a thing. You are doing everything right. No second guessing. 5-30 it is and keep it dino.
  15. May 9, 2010 at 4:19 PM
    Barnone
    Barnone Guest
    205k miles on dino and you want to switch?
    Keep doing what you been doing.
    Why waste the money?
  16. May 9, 2010 at 4:36 PM
    1980
    1980 Well-Known Member
    The Dust Bowl
    The poster who said you might want to use standard oil but increase the frequency of oil changes probably has the best answer.
    Switching to synthetic may do two things to a high-mileage engine: 1. the smaller molecules of the synthetic oil may find their way past seals and cause oil leaks. 2. the synthetic oil may break loose deposits, which sounds like a good thing but actually may contribute to blow-by and oil passage plugging problems.
    Another couple of things not do is to use engine flush or aftermarket additives as the former can wreak havoc on a high-mileage engine and the latter actually contribute to deposits and oil sludge.
  17. May 9, 2010 at 5:32 PM
    PPower05
    PPower05 Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    Your car has been happy on what you are using, clearly.... I wouldn't go out and get into sythetics with that many miles! If it is not broke, dont fix it!
