Help with Taco Maintenance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoNight14, May 2, 2024.
  1. May 2, 2024 at 8:33 AM
    TacoNight14
    TacoNight14 [OP] Member
    2014 Black Tacoma TRD Sport
    What's up everyone. New to the forum and new to everything that is the Tacoma.
    Recently I was able to purchase a 2014 TRD Sport V6 with 45k miles.
    Personally happy with this find seeing as it's not often I can get a vehicle I want in good condition.
    I need help though understanding the packages and their respective maintenance.
    So as far as I can determine it is a PreRunner, V6, TRD Sport, non 4x4, 2wd.
    Changed the plugs and oil myself after buying. Driveshaft is a Spicer U-joint with no zerk fittings, not sure what model yet but seems to be sealed so can't grease myself. Also can't seem to find if there is a front differential based on other photos of similar models. This is creating confusion as to what I can or can't do DIY.
    Can anyone sort this out by chance and help me understand?
    HondaGM likes this.
  2. May 2, 2024 at 8:35 AM
    Shellshock
    Iowa
    If it’s 2wd, there’s no front differential
  3. May 2, 2024 at 8:36 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    You wouldn't have a front diff on a 2WD truck.
    wilcam47, TacoNight14[OP] and HondaGM like this.
  4. May 2, 2024 at 8:48 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Pre-Runner is 2wd, no front diff, front driveshaft or transfer case. Everything else is the same as a 4wd truck.
  5. May 2, 2024 at 9:22 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Rear diff fluid can be changed, throttle body cleaning. Check ball joints tie rods, any other rubber or boot for wear.
    HondaGM likes this.
  6. May 2, 2024 at 9:32 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW...
    TacoNight14[OP] likes this.
  7. May 2, 2024 at 10:26 AM
    TacoNight14
    Ah ok, so front differential only applies to 4wd. That makes more sense, thanks.
    ToyoTaco25 likes this.
  8. May 2, 2024 at 10:28 AM
    PapawYota
    PapawYota TacoRojo
    2012 Tacoma
    welcome to TW.
  9. May 2, 2024 at 10:37 AM
    TacoNight14
    I did happen to clean the throttle body. Going to check the state of the rear diff this weekend.
    As for the ball joints and tie rods, YouTube has been handy.
    SethM[QUOTED] likes this.
  10. May 2, 2024 at 11:15 AM
    TacoTuesday1
    SD CA
    Not sure what the question is.
    2wd means no front diff.
  11. May 2, 2024 at 11:47 AM
    NC Gazzer
    Durham, NC
    If you're planning on replacing the rear diff lube, make sure you can open the fill plug before you drain it. It's a bummer if you drain but then are unable to refill.
    YF_Ryan and SethM like this.
  12. May 2, 2024 at 2:01 PM
    herecomesace
    herecomesace Well-Known Member
    2013 Tacoma TRD Offroad Access Cab MGM Supercharged
  13. May 2, 2024 at 3:12 PM
    Soft Taco
    Soft Taco Team Oil Drop
    Tyler
    Colorado Springs, CO
    2016 4WD Auto DCLB TRD Sport
  14. May 2, 2024 at 5:35 PM
    AJwisco
    AJwisco Well-Known Member
    2005 Tacoma sport
    People will laugh , but after the usual fluid changes I do when buying a used Toyota , I always either take the rear diff breather out and clean it or usually weld a nipple on it (after I take the little cap off) and run a breather hose up into the frame with a loop or two on the end.. I’ve had my share of fixing rear axle seals due to a clogged breather
    wilcam47 likes this.
  15. May 2, 2024 at 6:09 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    You shouldn't need a lot of non-fluid maintenance on a 2014 with 45k unless it was driven through a swamp or a pig farm or something. That's barely outside of the first engine air filter change interval.
    kwanjangnihm likes this.
  16. May 3, 2024 at 8:12 AM
    TacoNight14
    I normally would think the same. I got mine shipped up from Florida, and it was in Georgia as a fleet vehicle before that, reported that it was serviced extensively in that time. But because people are people, I leave nothing to chance and have to check things myself: oil cap showed signs of gunk, spark plugs had some oxidation.... went ahead and just changed it.
    2015WhiteOR[QUOTED] likes this.
  17. May 3, 2024 at 8:15 AM
    TacoNight14
    Absolutely. I've been saving maintenance vids and that fill plug was a key note.
  18. May 3, 2024 at 8:56 AM
    TacoNight14
    Sorry, that was a lot of info. Mostly got my answers but basically I needed to know what package my truck has, and based on that, what is the DIY maintenance to look out for.
  19. May 3, 2024 at 9:19 AM
    2015WhiteOR
    Gainesville TX
    Oil cap gunk would mean short tripped; was not regularly driven long and hot enough.. not a huge deal but make it a point to monitor.
    New plugs makes sense because 30k is the factory interval if using the regular NGK/Denso plugs. Most here recommend sticking with the factory plug specs and doing 30k since it's not that hard.
    You might also consider doing the mod for the SAI (secondary air injection) pump. This involves removing a foam filter that can degrade and kill the pump, and replacing it with a PCV breather filter.
  20. May 3, 2024 at 10:57 AM
    TacoNight14
    That might make sense with the age and low miles, otherwise that's helpful info. Regarding the breather filter and SAI, are there any videos on Youtube you might know of that can help me do that, or what to search for?
