Help with the name of the mount that the radiator support mounts to
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mojo blues, Oct 16, 2017.
  1. Oct 16, 2017 at 12:26 PM
    Mojo blues
    Mojo blues [OP] Member
    Jo
    1996 Toyota Tacoma 4x4 xtcab
    None
    image.jpg It's centered in the pic . I had a recent fender bender and the mount (black support welded to frame )bent way out of whack . Can these be bought new ? Any help would be very much appreciated.
  2. Oct 16, 2017 at 1:21 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    No, that comes as part of the frame, it is not a separate piece you can buy. It would be pretty simple to fabricate one and weld it on if you or someone you know is capable of that.
  3. Oct 16, 2017 at 1:28 PM
    Mojo blues
    Jo
    None
    Thanks. I've given some thought to make my own and weld them on but just wanted to see if it were possible to get these two mounts. Too new to repairing and finding toyo parts.
    Thanks a bunch.
  4. Oct 16, 2017 at 2:41 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
  5. Oct 16, 2017 at 2:53 PM
    Mojo blues
    Jo
    None
    Thanks so much for the kickass link
  6. Jul 16, 2018 at 5:06 PM
    BIllyBoyWilly
    BIllyBoyWilly New Member
    2001 TRD 4x4
    Late addition to this thread... any update on your situation? I came upon this as it just happened to me and i need to figure out what to do. After little fender bender bumper bracket isn't able to connect snugly with this mount bent. I would love to know how you fixed it and/or how it has held up as is.
  7. Nov 24, 2018 at 7:27 AM
    Fox hunter
    Fox hunter New Member
    2002 tacoma
    Well, I ended up needing the same part after being in a fender bender. I called junkyards and they either wouldnt let me cut it off a totalled one or wanted outrageous prices for the damn thing. I looked at rancho toyota like mentioned above and was going to find out if they would cut one off and send it to me until I found this website. They have any and every toyota part you could want or need down to specific pieces of the frame individually or as a whole. Just figured i would post this on here for the others that may find this thread and need help finding one. Note: link is for passenger side bracket, they have both sides and anything else you may need as well. https://parts.autonationtoyotasouth...0YWNvbWEmeT0yMDAyJnQ9YmFzZSZlPTMtNGwtdjYtZ2Fz.
