Help with tie rod ball joint ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jdkilroy, Nov 2, 2013.
  1. Nov 2, 2013 at 5:20 PM
    jdkilroy
    jdkilroy [OP] Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    I was putting the front end back together today and all going well until I tried to replace the tie rod castle nut back on the ball joint. It went on so far and then the ball/stud began to spin with the nut. I have not figured out how to stop the ball from spinning. Unlike the sway bar links, there is no hex socket cut into the end of the stud to secure it while tightening the nut.
    Any help appreciated so I can wrap this thing up.
  2. Nov 2, 2013 at 5:29 PM
    Large
    Large Red
    Tap the bottom of the tie rod in to the spindle a little bit, when it's in far enough it won't spin with the castle nut.
  3. Nov 2, 2013 at 5:29 PM
    AllMountainToy
    AllMountainToy Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    Thus happened to me on my 2nd gen on driver side when putting on OME lift
    I believe I either pulled on the knuckle of pushed on it while tightening and it fought and went back no problem.
  4. Nov 2, 2013 at 5:31 PM
    BamaToy1997
    Bill
    Navarre, FL
    Have ran into this a million times when reconnecting tie-rods. I usually take a pry bar of some sort and pry the tie rod towards the spindle while tightening the nut.
  5. Nov 2, 2013 at 5:31 PM
    Large
    Large Red
    Either way works really, I do all my stuff by myself so not having to hold the spindle helps a lot.
  6. Nov 2, 2013 at 5:35 PM
    jdkilroy
    Jon
    Southern NH
    Thanks a lot guys. I removed all three with a few taps from a three pound maul, I'll try setting it back in the socket with a couple more taps.
    Gotta say, I've learned a ton doing this job.
  7. Nov 2, 2013 at 5:36 PM
    Large
    Large Red
    First time is always the hardest, after doing it 20 times or so it gets a lot easier.
