Help with tire size?
Discussion in 'Wheels & Tires' started by So.Cal Taco, Jul 24, 2011.
  1. Jul 24, 2011 at 3:31 PM
    So.Cal Taco
    So.Cal Taco [OP] Well-Known Member
    Jeremy
    So.Cal
    1996 4x4 v6
    Total Chaos Long travel Total Chaos Spindle Gussets, Nathan Air Chime K3LA's,Onboard Air system,K&N intake,Chuys 200 plus Amp Alternator,All Pro front Bumper,Lots of Dynamat,99 tacoma Gas Tank Mod ''Secret'' maybe I'll Tell
    Hi all i cant find any info on 1st gen tacomas with 2.5 inch to 3 inch lift I have new 17'' wheels and looking at getting a set of BFG All Terrains will the 285 70 17's rub I have king 2.5 coil overs and im on 31x10.5x15 with a big gap any Help?
  2. Jul 24, 2011 at 3:36 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    re-read your question pal...sorry, been out in the sun all day :eek:
    Yes they'll fit, just do some minor trimming inside the fender and you'll be gold
  3. Jul 24, 2011 at 3:43 PM
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    Dude how did a pix. of my truck get on your last thread. If I did it sorry , no clue how.
  4. Jul 24, 2011 at 3:47 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    Thanks sorry should have posted in 1st gen
  5. Jul 24, 2011 at 4:32 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    What's the backspacing of the new wheels. For a first gen, you'll want 3.75-4" or so to fit the 285s.
  6. Jul 24, 2011 at 4:49 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    All pro Told me 4.5'' back space
  7. Jul 24, 2011 at 4:53 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    That's what the stock rims have. You'll be better off with 3.75-4 inches so you don't rub the uca on a wider 285mm tire
  8. Jul 24, 2011 at 4:55 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    Wow to late now i guess Walker evans and another local wheel shop said 4.5 is what i want for a 96 taco.
  9. Jul 24, 2011 at 5:00 PM
    malander
    max
    01 limited trd 4x4
    It might work out but you won't know until it's all mounted up. You could get wheel spacers or just return the rims for some with a different backspacing. Maybe someone with 4.5" backspacing and 285s could chime in
  10. Jul 24, 2011 at 5:08 PM
    KPT
    09 Prerunner
    4.5" is stock for a 96
  11. Jul 25, 2011 at 6:33 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    I know the stock wheels are 4.5 back space. Why did All pro,Total chaos and Walker Evans Tell me 4.5 is what to run on 17's :confused:
