Help with tire sizing for 16” rims TRD off rd
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacomadude4life29, Aug 21, 2022.
  1. Aug 21, 2022 at 5:15 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Nope, but glad they are the lighter, smoother C Load, instead of an E Load.
  2. Aug 21, 2022 at 5:33 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Passenger cars and light duty trucks typically use P rated (passenger car tires). They are sometimes listed as SL (standard load). Depending on the size each tire has a load rating of around 2000-2500 lbs per tire. Way more weight than you'd ever put in a Tacoma or 1/2 ton truck.
    They also make Light Truck tires (LT) that come in different load ratings. A C rated LT tire is rated for about the same weight as a P or SL tire. You can also find D rated tires, which are rated to carry a little more weight. But C and D rated tires are not common and with limited choices. Most 3/4 and 1 ton trucks use E rated tires which are rated for well over 3000 lbs each. They also make F and G rated tires, but that is for even larger trucks.
    All of the larger tires are only available in LT load ratings, mostly E rated. They are heavier, around 50-55 lbs each vs 38-40 lbs for P or SL tries. The engine has to work harder to turn them and performance is reduced. But even though they aren't needed for the weight, they are a much tougher tire less likely to be damaged off road.
    For off road use you'll never notice the loss of power, but on road E rated tires will slow down acceleration. Especially with the 4 cylinder engine.
  3. Aug 21, 2022 at 7:38 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    You and me buddy. You and me.
  4. Aug 21, 2022 at 7:42 PM
    RushT
    North Texas
    How are you liking the noise on these? I had them on my FJ and damn they got loud quickly. After each rotation it would only take about 1000 miles before it got louder (they never really got very quiet). I honestly don't remember the rating; but am pretty sure I stayed with the stock size.
  5. Aug 22, 2022 at 8:22 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Not going to lie, they are louder because they're the most aggressive of all the A/T tires. But they are that not loud, they just have a little hum to them, which I kinda like.
    Duratracs are the closest to a M/T tire, but with much better on-road charaistics. And the 3 peak snow designation is a bonus.
  6. Aug 22, 2022 at 8:28 AM
    WeeBrain
    WeeBrain Well-Known Member
    Erik
    PA
    22 TRDOR
    This is the way
  7. Aug 22, 2022 at 9:17 AM
    JakeJob
    JakeJob Well-Known Member
    Jacob
    NW Indiana
    '22 LR Tacoma TRD ORP MT
    I agree this is a nice tire.
    Tocamo[QUOTED] likes this.
