Help with torx bolt removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scifidelity, Apr 16, 2019.
  1. Apr 16, 2019 at 6:32 PM
    scifidelity
    scifidelity [OP] Well-Known Member
    having a hard time getting the furthest back two T55 bed bolts and the two tie down bolts (t40) out. Trying to install my total chaos bed stiffener which is of course not going well. Thanks.
  2. Apr 16, 2019 at 6:34 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Get a breaker bar that's the only way you are getting it out. Long and usually rusted.
    whatstcp likes this.
  3. Apr 16, 2019 at 6:34 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Dremel heads to fit on a large socket
    MitchK likes this.
  4. Apr 16, 2019 at 6:40 PM
    Ducman82
    Ducman82 Well-Known Member
    jake
    2016 Sand Tacoma TRD
    breaker bar if not stripped.
  5. Apr 16, 2019 at 6:42 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  6. Apr 16, 2019 at 6:46 PM
    vwarwar
    vwarwar Member
    Vitor
    Tacoma 19
    Iem # 832032 Model # SPEEDPRO1
    SpeedOut 8-1/8-in Double-Ended Screw Extractor
    Lowe’s has them. Obviously, you will need a new screw..
  7. Apr 16, 2019 at 6:47 PM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    wahoobie likes this.
  8. Apr 16, 2019 at 6:51 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Tullie D likes this.
  9. Apr 16, 2019 at 7:23 PM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    little heat underneath doesnt hurt either, just dont heat the plastic of the bed...
  10. Apr 16, 2019 at 7:24 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I used a breaker bar, but they came out pretty easy. Just be gentle, torx either strip out or you accidentally twist the bit., both bad.
    wahoobie, shakerhood, SR-71A and 2 others like this.
  11. Apr 16, 2019 at 7:29 PM
    scifidelity
    2 ft. Breaker bar FTW! Thanks fellas! Better believe I slathered ‘em up with grease before reinstalling
    SR-71A and JoeCOVA like this.
  12. Apr 16, 2019 at 7:29 PM
    CTtoNoVa
    Pop N Lock
    Yep, slow and steady
    JoeCOVA[QUOTED] likes this.
  13. Apr 16, 2019 at 9:05 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    Did mines a couple weeks ago. I was lucky (or unlucky) to be able to get it going with just a 1/2” ratchet. It was tough but still managed to get it off without a breaker.
  14. Apr 17, 2019 at 3:12 AM
    CTtoNoVa
    Pop N Lock
    You are an animal
    wahoobie and scifidelity[OP] like this.
  15. Apr 17, 2019 at 4:53 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    TomTwo[QUOTED] likes this.
  16. Apr 17, 2019 at 4:56 AM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    Impact gun needed for me. Felt like I would strip it when I tried by hand
    whatstcp and Early Man like this.
  17. Apr 17, 2019 at 6:04 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    I had to use one of these on the bed rail screws that was stripped from the factory. I was more surprised that it actually got the screw out
    TomTwo likes this.
  18. Apr 17, 2019 at 7:25 AM
    scifidelity
    Man I've used these on smaller bolts before. Seems super dicey on such a long thick bolt though.
  19. Apr 17, 2019 at 7:27 AM
    scifidelity
    Yeah i need to get some air tools. I have a decent porter cable compressor already for nail gunning. I did try my 20v professional grade impact driver, that didn't budge it!
  20. Apr 17, 2019 at 7:47 AM
    CTtoNoVa
    Pop N Lock
    3/8 or 1/2 inch drive?
