Help with TRAC OFF and check engine light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pirhett, May 10, 2015.
  1. May 10, 2015 at 9:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Might just need to be tightened , but you would still need to get the code read / cleared
  2. May 10, 2015 at 9:52 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    So your 30" light bar is drawing power from a switch that probably takes less than a couple of watts? That's way to much power draw of off such a low current circuit, your light bar takes 10x the power of that switch at least. Or is the switch just drawing the power to light itself from the TRAC switch? Either way I woulf say it's probably not a coincidence you install a light bar that draws powet from the TRAC button and then you get a code, but as others have said it would be best to know the codes before blaming the switch.
    A ton of little things will disable TRAC and set off the check engine light. It could be literally anything and a ten minute trip to an autozone or an appointment at the dealer will give you some real answers.
  3. May 10, 2015 at 10:31 PM
    Pirhett
    Pirhett [OP] Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    Oh no... My light bar is all wired properly to the battery and grounded and has an inline fuse, the only thing wired to my traction control switch is a single wire from my after market switch. That one wire I tapped to make it so when I turn my lights on normally the fog and TRAC green light behind the switch goes on and now so does the light on my switch for my light bar. That's all that is wired to the other switch.
  4. May 11, 2015 at 7:54 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Okay. That makes a lot more sense. The only thing I'd still point out though is that even though the light in that switch doesn't draw much power, that circuit is a digital switch. In simpler terms the TRAC button doesn't actually have a true mechanical on/off switch in it. Instead it has a switch that turns off momentarily when the button is depressed which tells the TRAC computer to shut off TRAC or enter other TRAC modes. Given the functionality of the switch I wouldn't wire anything into that circuit that could cause a voltage drop because it could trigger an issue with the TRAC computer, though I would think at worse TRAC would turn on and off randomly when the lights are turned on it could very well cause something strange like a check engine and TRAC light.
    As OZ and others have said there is no real way to know what is going on without knowing the codes. My piece of advice would be to pick up a code reader, or even better value for the money a Scangauge or Ultragauge, and grab those codes yourself. Once you post them members can likely pinpoint what is actually going on with your truck. It could be the gas cap, ABS sensor, or something else totally unrelated to TRAC system but until we have more information we are just feeding you random guesses.
  5. May 11, 2015 at 8:06 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    What code did it throw?
  6. May 11, 2015 at 8:20 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Funny how electrical stuff wants to stay dry. Goes to show how even something that isn't related to TRAC in anyway can mess with it.
  7. May 11, 2015 at 8:53 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    My last Outback would disable VDC, SI-Drive and Cruise Control for any check engine light. It would also set the rev limiter at 4k until you restarted the car. I think lighting up the dash like a Christmas tree was a strategy to scare owners into thinking there was a big problem so they didn't just ignore it.
  8. May 11, 2015 at 11:40 AM
    Pirhett
    Rhett
    San Diego
    Stock...
    welcome to the club, I took off my after market lockable gas cap and reset my electric stuff and the lights still went on after 10 min. dam annoying
  9. May 11, 2015 at 5:36 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    My buddy at work has an old Subaru outback that disables it's cruise control of his O2 sensor codes. He has a buddy clear the code and he is good for six months.
  10. May 11, 2015 at 6:17 PM
    OZ-T
    Peter North
    British Columbia
    Did you get the code read yet ?
  11. May 11, 2015 at 6:53 PM
    OZ-T
    Peter North
    British Columbia
    How bout now ?
  12. May 11, 2015 at 7:15 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Or a non-OEM cap that isn't tight enough. :)
  13. May 11, 2015 at 8:45 PM
    OZ-T
    Peter North
    British Columbia
    Repost Jimmah
  14. May 11, 2015 at 8:53 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Why not just elimante the possibilities of what it could be, and take it to Autozone or something and get the code read so you know if it's something you did and need to take care, or the dealer needs to take care of.
    It doesnt cost a dime to have the code checked at Autozone...or a dealer since its new.
  15. May 11, 2015 at 11:24 PM
    #35
    Pirhett
    Rhett
    San Diego
    Stock...
    Taking it to Toyota tomorrow! I'll get back to you guys once all is done!
  16. May 12, 2015 at 12:31 AM
    #36
    Jimmyh
    SC
    2012 Prerunner SR5
    While your at the Toyota dealer get them to read the codes for the CEL.
  17. May 12, 2015 at 8:04 AM
    #37
    Pirhett
    Rhett
    San Diego
    Stock...
    Okay! What does CEL mean lol
  18. May 12, 2015 at 8:14 AM
    #38
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Check engine light
  19. May 12, 2015 at 1:34 PM
    #39
    Pirhett
    Rhett
    San Diego
    Stock...
    Okay guys at Toyota and having them check it all, right when I rolled up a maintence light came on. I have an oil change due in 300 miles so idk if that caused that. I hate all these light things haha
  20. May 12, 2015 at 1:51 PM
    #40
    Pirhett
    Rhett
    San Diego
    Stock...
    Okay sweet so that's not a worry and I'm still waiting on the other lights. I'm gunna be pissed if something is wrong. Idk how my TRAC off light went off since I haven't wheeled hard more than 5 times and it's been about 1,200 miles since the last time I did
