Help with Transfer Case Maintenance 1999 SR5
Discussion in '1st Gen. Tacomas (1995-2004)' started by thruhiker, Apr 12, 2012.
  1. Apr 12, 2012 at 6:41 AM
    thruhiker
    thruhiker [OP] Member
    Fort Collins, CO
    1999 SR5 3.4L V6
    Hi Folks,
    I have a 1999 Tacoma SR5 3.4 L V6. I am wanting to change out the transfer case fluid. Can anyone tell me what size Wrench I need to remove the drain and fill plugs? My 22mm was just a little small so I am suspecting I need a 24mm. :cool:
    Thanks!!
  2. Apr 12, 2012 at 6:48 AM
    BeerHat
    BeerHat Got Beer?
    TX
    2001 PreRunner 4x4
    PreRunner 4x4, Homebrew Front Bumper, Homebrew Sliders, Homebrew Skids, Homebrew Bedbar, Homebrew Beer
    24mm is the correct answer.....
  3. Apr 12, 2012 at 7:01 AM
    thruhiker
    Fort Collins, CO
    1999 SR5 3.4L V6
    Thanks Beerhat!!
    Would the wrench size be the same for the transmission fluid plugs?
    Thanks from a novice
  4. Apr 12, 2012 at 3:53 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    a good sized crescent wrench will work
  5. Apr 13, 2012 at 2:28 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Yes 24mm for both transfer and tranny.
    And torque specs....
  6. Apr 13, 2012 at 2:30 PM
    boshak
    AG
    CA
    Also, make sure you take off the fill plug first! That way you dont drain the oil, realize you cant open up the fill plug, and leave your truck stuck at home.
