Help with transfer case oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by acparker12, Apr 21, 2022.
  1. Apr 21, 2022 at 4:06 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    No. The plugs are 24mm external hex like the rear diff. Crush washers are a different type, too, because the T-case is aluminum.
    While there is a synchros in the T-case, Toyota has spec'd GL5 in there since 1995 with no issues. 75W90 will be fine.
    TnShooter and Supr4Lo like this.
  2. Apr 21, 2022 at 4:10 PM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I wasn't trying to turn this into an oil debate. Was just giving OP options, and info he could look into if he so pleased.
  3. Apr 21, 2022 at 6:48 PM
    acparker12
    acparker12 [OP] Well-Known Member
    Penns Valley, PA
    2014 MGM Tacoma TRD Sport 4x4
    Still figuring it out…
    Thanks I have the front drain/fill plugs since the hex likes to strip out on them. The rear will need replaced I’m sure since they like to round off but didn’t know about the transfer case. Just got underneath it, they are the same external hex as the rear, just have to find them and order them to be here by Thursday.
  4. Apr 21, 2022 at 7:02 PM
    acparker12
    Penns Valley, PA
    Unfortunately it looks like they haven’t even been touched, no marks on heads or anything, so at 95,000 miles it’ll get it’s first front, rear and transfer oil change. This truck was in every 5000 miles at the toyota dealership to get oil changed and serviced (according to the carfax report) you woulda thought they would’ve done that at least once.
