Help with two check engine codes
Discussion in 'Technical Chat' started by LifeFeedsOnLife, Jun 15, 2013.
  1. Jun 15, 2013 at 3:03 PM
    LifeFeedsOnLife
    LifeFeedsOnLife [OP] New Member
    My check engine light has been going off and on for a while now but recently stayed on. I got it checked at autozone today. The codes that popped up are P0157 which is heated o2 sensor- bank 2 sensor 2 circuit low voltage. And P0606 which is failed ECM. I'm hoping that its only the O2 sensor causing the problem. Any suggestions whether I need to replace the sensor itself or if the wiring has to do with it?
  2. Jun 17, 2013 at 9:06 AM
    BamaToy1997
    Bill
    Navarre, FL
    There is no way to just guess at if the sensor is bad or the wiring is a problem. While Tacoma O2 and A/F sensors are pretty common to failures, there is no way anyone here can tell you what is wrong with your particular truck with 100% certainty. While I am not one to suggest throwing parts at a problem, if you wanted to just try it, you could replace the suspected sensor, clear the codes, and then test drive it to verify the fix. Other than that you will need a good multimeter and wiring schematics for your truck to actually verify the fault.
  3. Jun 17, 2013 at 9:09 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Especially without any info about his truck.
    Person: Hey Doc, My head hurts.
    Doc: Sounds like a brain tumor, we must perform surgery now.
  4. Jun 18, 2013 at 8:15 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    How many miles are on the sensors ? anything 90,000 - higher you
    can pretty much bet it is a sour sensor (they do age out and crap out)
    typically 130,000 miles your a/f or o2 are end of life pretty soon
  5. Jun 18, 2013 at 8:30 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    The FSM has instructions for testing them. I don't have mine in front of me or I would post them.
  6. Jun 18, 2013 at 9:24 AM
    LifeFeedsOnLife
    Alright thanks guys. I'm going to replace the sensor and see what happens after that.
  7. Jun 18, 2013 at 2:38 PM
    BamaToy1997
    Bill
    Navarre, FL
    Curious, I read O2 sensor data and heater voltages all the time with my multimeter.
  8. Jun 19, 2013 at 6:24 AM
    BamaToy1997
    Bill
    Navarre, FL
    I see what you are meaning, but I use this data all the time to help me diagnose a faulty O2 sensor. While I agree that a digital oscilloscope is the best way to get solid numbers, they are much too expensive for a shop to own. I have had no problems at all finding failed O2 sensors simply with my scan tool and a digital multimeter. My scan tool has a built-in scope display which shows waveform, so I am good there.
