Help with understanding Rims for replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elljtandthesea, Aug 29, 2019.
  1. Aug 29, 2019 at 7:22 AM
    elljtandthesea
    elljtandthesea [OP] Member
    2006 Tacoma TRD
    Hello all. I am new to this forum and recently bought my first Tacoma, she’s a 2006 4 door TRD.
    I am looking to replace the rims as they have some corrosion and are a little bit of an eye sore. If I purchase 16” rims aftermarket what else do I need to look for to make sure they will fit my truck? Other than the 6 lug nut pattern. I’ve found some new rims taken off of a 2018 Tacoma...if they are 16” should they fit fine? Thanks for the help!
    Elle
    bigmw likes this.
  2. Aug 29, 2019 at 8:58 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Welcome to TW, Elle!
    Rim measurements with which to be concerned include...
    - Diameter (which you listed) = distance from one side of the rim's bead seat floor to the opposite side's bead seat floor, not the diameter of the outer rim edge
    - Width = distance from the outboard bead seat to the inboard bead seat
    - Backspace = distance from the hub mounting surface to the inside lip of the wheel
    - Offset = location of the center section's hub contact face, relative to the mid-point of the rim width
    - Number of lugs (which you listed) = self-explanatory
    - Bolt pattern = the diameter of an imaginary circle formed by the centers of the wheel lugs
    - Stud size = stud diameter x thread pitch
    - Center bore = size of the center hole in the wheel that centers it on the hub
    IIRC, 2nd Gen 6-lug Tacomas came with
    - 16"-17" diameter
    - 7"-7.5" width
    - 5" backspace
    - +30mm offset
    - 6 X 140mm bolt pattern
    - M12 X 1.5 stud size
    - 106mm center bore
    Not sure where you're shopping rims, but Discount Tire and TireRack both allow shopping by vehicle, displaying a variety of options that will fit. Good luck!
    bigmw likes this.
  3. Aug 29, 2019 at 10:49 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Some aftermarket 16s will rub the calipers with the wheel weights on. Be careful. We had 1 idiot that did this and wanted his wheels balanced once a week and complained that they hit the calipers, no shit jackass, buy wheels that fit properly. My factory 16s clear the brakes with no troubles. Even if I stack the weights 5 high
    Norton likes this.
  4. Aug 29, 2019 at 11:08 AM
    Ninjarabi
    Ninjarabi Well-Known Member
    Oregon
    2012 Blue Tacoma TRD Sport DCLB
    Leveling Kit, Tonneau Cover, 285/70/17 Tires, Moto Metal 970 Rims, Remote Anywhere start, Grill Guard, 30" Light bar, PIAA Headlights and Fog lights, LED bed lights, Led Hood Lights, Magnaflow Exhaust with tip, Heated Seats, Sun Roof
    From my experience going into one of the @Discount Tire shops, or a shop that works with Tirerack or Tire Pros have given me good advise on what will fit and what wont. This way if I like a certain rim, and Im not sure I can have a person to ask questions to.
    spitdog and Norton like this.
  5. Aug 29, 2019 at 11:12 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    If you plan on keeping your current tires and want to save money, why not sand off the corrosion on your current wheels and rattle can paint it whatever color of choice? BTW, welcome to TW.
  6. Aug 29, 2019 at 11:17 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    I highly doubt OEM wheels have a BS of 4", given that offset. Most OEM wheels have backspacing closer to 5.5".
    Norton[QUOTED] likes this.
  7. Aug 29, 2019 at 11:35 AM
    Norton
    Good catch. Typo fixed, though I thought it was closer to 5".
  8. Aug 29, 2019 at 12:04 PM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    The more common OEM wheel style pictured for the 2nd gen Tacomas are roughly 5.4" bs due to being 7.5" wide. There are some styles that are 7" wide that are closer to 5"bs.
