Help with upper ball joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by guinness, Jun 30, 2015.
  1. Jun 30, 2015 at 4:12 PM
    guinness
    guinness [OP] Member
    So Ive replaced both the driver and passenger side ball joints twice so far. They seat properly, the boot is fully on facing the right direction, and it is tightened to spec. But for some reason the ball joint will not hold grease for more than a couple hours or until I drive somewhere. It vibrates when I come to a stop or slow down from 40ish mph and I feel its getting worse. Any one had this problem, or have any info that could help me figure out why this is happening. Both sides are failing, Replaced with MOOG K90255 upper ball joint both times. 1995 DLX v6 3.4 4x4.
    Thanks,
  2. Jun 30, 2015 at 4:14 PM
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    is the grease coming out of the boot?
    how do you know its not holding grease?
    just curious :)
  3. Jun 30, 2015 at 4:17 PM
    guinness
    Yes. it leaks out from the bottom of the boot on both sides after sitting for about an hour, or if I drive somewhere.
  4. Jun 30, 2015 at 5:58 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    moog is pure crap and the boots never seal
    replace with oem ball joints and your done, you don't save any money buying aftermarket crap because as you see they don't last and now you have to replace them again
  5. Jun 30, 2015 at 8:58 PM
    Rschap
    Rschap Active Member
    Randall
    Grand Junction
    98 4X4 Limited
    How are the control arm bushings? Also check the tie rods. The only other thing I can think of is, what kind of grease are you using?
    I have had nothing but good luck with Moog parts.
  6. Jul 1, 2015 at 12:17 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Go Toyota and be done .
    Sure more expensive to start but great piece of mind.
    In the past Moog used to be the aftermarket go to suspension and steering parts no longer!!!
