Help with URD Stage III Clutch and PDM Kit set up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ODICA, Dec 5, 2011.
  1. Dec 5, 2011 at 10:45 PM
    ODICA
    ODICA [OP] 06 TACOMA 4X4
    Earl
    Beaumont, CA
    06 4X4 SR5
    Does anybody know if somebody is running this setup? Please feel free to chime in.
    I had installed the URD Stage III clutch kit paired with PDM throw out bearing, and had put on about 6k miles of break in period. Now, its just that its getting harder for me to get it on 1st and pulling it in 2nd sometimes when I get stuck on traffic, sometimes I have to put it on 3rd just so I could shift to 1st. Do you guys think I need to bring the clutch to get it pressurized bleeding? Just don't know where to start.:confused:
  2. Dec 6, 2011 at 7:18 AM
    Wally
    Wally Well-Known Member
    Ontario (the metric version)
    07 Access Cab TRD 4x4 6MT 1GR-FE
    Which version of the throwout bearing are they supplying with the kit now? They machine a Toyota TB to fit the sleeve but Toyota issued an update as part of the TSB and it sits farther forward than the old one.
    The new clutch release cylinder is longer to compensate and get the right amount of travel. If you have a new TB but an old clutch release cyclinder then the travel won't be long enough, even if it's properly bled.
    I'd call them and check the part #'s or at least bring up the issue. Your 06 would have the shorter clutch release cyclinder if it's the original one.
  3. Jan 28, 2014 at 9:59 PM
    Talon12012
    Talon12012 New Member
    Medford, OR
    05 Tacoma 4x4 SR5 access cab
    6" fab-tech lift, 35" open country, xd wheels, TRD intake, single chambered 10 series flow master
    Hey Just wondering if you had any resolution on this issue. I am literally about to install the exact same set up along with a URD short throw shifter so, if I can do anything now to alleviate ass pain later that would be great
  4. Sep 5, 2014 at 11:09 AM
    kain102708
    kain102708 Well-Known Member
    Stan
    Denver
    08 DBCB TRD Off Road
    rear locker anytime mod, lifted
    Sorry guys, but are you referring to the release cylinder as the slave cylinder. I recently installed this set up and did not replace.
