help with Vapor Canister (77740-35470) question
Discussion in '1st Gen. Tacomas (1995-2004)' started by NotDr.Phil, Dec 10, 2017.
  1. Dec 10, 2017 at 7:48 AM
    NotDr.Phil
    NotDr.Phil [OP] Member
    Roy
    2001 Taco PreRunner, 3.4L V6
    I need a vapor canister for my '01 Pre-Runner (3.4L V6). OEM prices are $600-$750.
    I keep seeing various after-market parts for considerable less. A mechanic friend says aftermarket is ok but to STAY AWAY from anything made in China. Can anyone suggest a good aftermarket option?
  2. Dec 10, 2017 at 8:43 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I found an OEM canister on eBay for around $300.
    EDIT: $265, but that listing is no longer active.
    TOYOTA CHARCOAL CANISTER! VAPOR NEW OEM! 77740-04010 TACOMA 2001-2004
  3. Dec 10, 2017 at 9:01 AM
    cmf21
    cmf21 Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    Why do you need a new one? If it's leaking you can just epoxy up the seams around the bottom and save yourself some money.
  4. Dec 10, 2017 at 9:07 AM
    ghs57
    Chops
    Catskill Mts. NY
    I agree, cracks can be sealed. It's worth a try. Mine had bad VSVs, and Toyota doesn't sell them separately. Don't know if aftermarket VSVs are available for the canister.
  5. Dec 10, 2017 at 9:18 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    If a valve was needed, I would cross reference the part #, Toyota tends to use these kinds of parts on many models. (around same year)
    I would bet you could find something to work from a junkyard.
  6. Dec 10, 2017 at 9:41 AM
    NotDr.Phil
    Roy
    Thanks guys. I've ordered a length of hose and a new gas cap off eBay trying to fix on the cheap. If that doesn't solve the codes I will remove the canister, check for cracks & epoxy any I find. FYI, mine is the one under then hood, not the one under the truck bed (77740-04010).
  7. Dec 10, 2017 at 10:59 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I believe you can pressurize it to a couple of pounds, open the valve with a 9V battery and soap it for leaks.
  8. Dec 10, 2017 at 11:04 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    talk to the Gunny at Camelback Toyota,i got one there for a 1st GEN was the best priced OEM I could find(and I looked hard for the best price), there are aftermarket varieties available but I wouldn't trust the quality for an OEM that costs a few dollars more especially if you plan on keeping the truck forever.
  9. Dec 10, 2017 at 3:33 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    bought mine from carquest/advance auto parts when I was working there. they get it from an exclusive company called worldpac. worldpac gets a lot of OE products for less than dealer prices. this one was around 240 total at employee price which isn't much cheaper than walk in or shop price.
  10. Dec 10, 2017 at 5:22 PM
    ghs57
    Chops
    Catskill Mts. NY
    The 9v battery works good to test the valves. That's how I found my bad ones. Just use jumpers to connect the battery to the terminals on the valve. They will either click open or closed, depending on the specific valve. No click, no good. Since that solved my problem, I didn't look for leaks.
  11. Dec 11, 2017 at 7:08 PM
    col. sandurz
    col. sandurz Well-Known Member
    I have one of these for sale on classifieds. Guess I should raise the price. Pm me if you need it
  12. Dec 13, 2017 at 6:44 PM
    NotDr.Phil
    Roy
    Shop told me it was the VSV so I pulled it off, ordered the same part & replaced it. Also pulled the intake off & ran seafoam thru the throttle body and cleaned it really well. The CEL stayed off almost 300 miles then came back on.
    The 77740-04010 is, apparently, the canister that is mounted near the gas tank. The one under the hood is 77740-35470. Thanks for the input. I'm gonna try replacing the hoses & sealing any cracks I find. Will let you know what I find.
    One interesting thing: I have a pdf showing parts for an 01 Taco. The "canister" in the drawing of the components under the hood is actually the one that mounts near the tank.
  13. Dec 14, 2017 at 5:08 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Good choice to replace it, NotDr.Phil, that's what I did too. No sense in applying a seal that's just going to fail at an inopportune time a few months down the road. I got a Denso replacement and it wasn't cheap, but it's one less thing to worry about for the remaining life of the truck.
  14. Dec 14, 2017 at 5:11 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If you need one, have one sitting on the shelf.
