Help with vibration
Discussion in 'Suspension' started by 503TRD, Jun 27, 2011.
  1. Jun 27, 2011 at 6:02 PM
    503TRD
    503TRD [OP] Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    I recently lifted my truck more, and now have a vibe from about 4-9mph when accelerating. Or even slightly rolling at those speeds and in reverse. I have Bilstein 5100's all around, the fronts are set at 2.5" and I have the rear Toyota TSB, and then the 1.5" Toytec AAL for the TSB. How can I eliminate this vibe? When I put it into 4Hi, the vibe is gone, so is it a rear driveshaft problem? Would the carrier bearing drop kit and/or axle shims(what degree?) work? Or could I just take it to a dealer an see if they will do a driveshaft TSB that I think I read about.
    My rear wheel well is 39" from the ground(in the center) and the front is about 37". Could I get the toytec 3/4" lift spacers on top of the front 5100's to make it more level, and would that help the vibe or worsen it or do nothing? Because I want the front lifted like one more inch, but also wanna eliminate these vibes.
    Thanks in advance
  2. Jun 27, 2011 at 11:49 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Sounds like a typical rear drive line vibe. A 3 degree rear shim should take care of it.
    Not knowing your tire/wheel combo, what's the measured height straight up from the center of your front and rear hubs?
    Please feel free to email us at support@toyteclifts.com or send over a PM
  3. Jun 28, 2011 at 2:21 AM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    I have similar vibrations when driving at low speeds like through parking lots and school zones, I am a prerunner and lifted 2.5" up front and 1.5" in the rear.
  4. Jul 5, 2011 at 11:42 PM
    ratrod
    ratrod Well-Known Member
    Los Angeles
    2006 Toyota Tacoma Dbl Cab TRD SR5 4x4
    Bilstein 5100s @ 1.75 with 1.5 AAL, Satoshi Grill Mod with 2 Hella 500s behind the grill, LED dome and map lights, custom made (by me) 10" subwoofer box behind the dbl cab seat, DVD/iPod/Bluetooth/GPS/TV/USB/Stereo, Yakima rack, Shell, tinted front windows to match the factory backs. Backup cam in the tailgate handle mod.
