Help with water sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kja78, Jun 20, 2018.
  1. Jun 20, 2018 at 8:29 PM
    kja78
    kja78 [OP] Well-Known Member
    Kevin
    2015 Tacoma TRD Off Road Double Cab
    OK there all i need help. my 2015 double cab is making sounds like there is water in the passenger side B pillar, or somewhere around there. I have taken everything out of the truck to make sure it's not something else. I have once or twice seen water on the floor of the rear seats. Just thought maybe it was a kids spilled some water. But it's driving me nuts. I have looked on the internet and here and can't find a definitive...Help please
    Thanks for you time.
    Kevin
  2. Jun 20, 2018 at 8:32 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Maybe you have a half filled water bottle sitting in the cup holder in the door
  3. Jun 20, 2018 at 8:35 PM
    kja78
    Kevin
    I wish it was that easy. I have clean everything out of the truck. Only have 38K on it. I have tried clearing the A/C drain line and it doesn't seem blocked either. Sound is coming from B pillar or somewhere in the back area.
  4. Jun 20, 2018 at 8:45 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Mount holes dont go all the way through. Are you sure its from the pillar? Could be water coming in from the fresh are ac intake. I had that problem.
  5. Jun 20, 2018 at 8:46 PM
    TexasWhiteIce
    Texas
    Does it sound like peeing or water in a bottle or river water running or dripping?
    Or do you only hear it after you smoked some crack?
    Alexely999 and Santa Cruzin like this.
  6. Jun 20, 2018 at 8:47 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Plugged a/c drain causing fan air box to fill with water, maybe
    12TRDTacoma likes this.
  7. Jun 20, 2018 at 8:51 PM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Not sure because I have the access cab, but the holes on my 4Runner to mount the roof rack go through and will let water through if not sealed or have a bolt in it.
    Also op, where are you?
    DoorDing likes this.
  8. Jun 20, 2018 at 8:56 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    On my Tacoma, in the ridge where those rubber strips go, where the oem roof rack mounts, there are raised metal brackets where the bolts screw in.
  9. Jun 20, 2018 at 9:00 PM
    Dan H
    Dan H Wife thinks I'm having an affair with my Tacoma
    Daniel
    Glendale AZ
    2006 indigo ink PreRunner DCSB- 2012 Venza AWD
    ProComp Pro Runner shocks n struts Painted engine cover Fog anytime mod Cherrybomb muffler Bestop 3/16 tailgate plate and top cap Where do I begin with all the camo
    Does your truck gave drain plug in the rocker panel. It could have water trapped in it. Under accel or braking it could be coming inside to get the carpet wet.1529553484863139155229.jpg
  10. Jun 20, 2018 at 9:00 PM
    b_r_o
    b_r_o Beef jerky time
    Alex
    WA
    2015 DCLB
    Maybe a window seal leaking water into the door. Isn't there some plugs that can be pulled out to let water drain?
  11. Jun 20, 2018 at 9:06 PM
    kja78
    Kevin
    I don't have a roof rack, and had truck since new so never been tap into.
    I am in Vancouver,Washington
  12. Jun 20, 2018 at 9:08 PM
    kja78
    Kevin
    I will look at that. Mostly hear when truck rocks side to side.
  13. Jun 20, 2018 at 9:12 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Maybe pull the plastic piece between the hood and the winshield, see if water is being held in there. Could be a bunch of leaves and junk got in through the vents and holding water, that can make a water sound when you rock it back n forth.
  14. Jun 20, 2018 at 11:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The drain holes in the door should be open all the time, no plug.
  15. Jun 21, 2018 at 11:59 PM
    Dan H
    Daniel
    Glendale AZ
    Have you figured out the sound yet?
  16. Jun 22, 2018 at 5:22 AM
    HoulaHauler
    HoulaHauler Well-Known Member
    Andy
    Gwinnett Co., Georgia
    2013 1G3 DCSB
    Toyota had a run of back sliding windows that didn't have a good bond of urethane (it would bond to the body but not to the glass). Open a back door and push on the glass with the palm of your hand while looking outside at the molding of the back window. As you're pushing, see if the glass moves away from the body. If it does, that may be your problem. I'd suggest pulling the rear seat backs and store bins and then water testing the back window and seeing if anything comes in. Tumble the seat bottoms up, fold the seatbacks down, remove the small square covers and remove the 4 bolts for the seat backs (I think they're 12mm). Then there's 10mm bolts for the storage bins against the back of the cab. With the seat backs out, just pull straight back on the storage bins to release the clips (driver's side first as it overlays the passenger side bin). Grab a garden hose and go around the perimeter of the window for at least 5 minutes while checking the inside for any water entry.
