Help with wiring a relay for my lights
Discussion in 'Lighting' started by retired-rr, Sep 19, 2020.
  1. Sep 19, 2020 at 11:12 AM
    retired-rr
    retired-rr [OP] New Member
    Mario
    I hope that someone has a simple answer. I customized my molded mudflaps on my Silverado. I added a running light and a signal light. To keep it simple the running light is red+ and black- and the signal light is orange+ and green-. I want the running light to de-energize when the signal light gets energized. I have a bunch of 5 pin relays if that will be needed Thank you
  2. Sep 19, 2020 at 8:06 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome. Odd to ask a Silverado question on a Tacoma site. But regardless you need a normal closed relay feeding the running light that is tapped into the signal circuit. So when the signal is energized the relay is powered and opens to break the running light circuit.
  3. Sep 19, 2020 at 8:14 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Pin 85 (-)
    Pin 86 ( + orange signal light)
    Pin 87 not connected
    Pin 87a (red running light, source side)
    Pin 30 (red running light, light side)
    *Must break up (Cut) the running light wire and run each side through pins 87a and 30 on the relay
    HisDad likes this.
  4. Sep 19, 2020 at 8:59 PM
    caribe makaira
    Caribbean, Puerto Rico
  5. Sep 20, 2020 at 3:28 AM
    retired-rr
    Mario
    Thanks guys this did help. I do appreciate your knowledge and your help. Sorry I didn’t pay attention to the group name before I joined and posted. A friend just sent me the link and said that I would get my question answered. Thanks again.
