Help with wiring for LED pods please
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 17tacosport, Aug 14, 2017.
  1. Aug 14, 2017 at 12:04 PM
    17tacosport
    17tacosport [OP] Well-Known Member
    Hasmeet
    Buffalo,NY
    2017 MGM Tacoma DCLB 4x4
    So I got the wiring harness for the led pods from Cali raised and the harness doesn't have a ground and I have never seen these colors for the harness before please let me know if anyone knows what to do.
  2. Aug 14, 2017 at 12:20 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
  3. Aug 14, 2017 at 12:22 PM
    trdsupreme
    trdsupreme Well-Known Member
    2017 TRD OR DCLB Silver Sky
  4. Aug 14, 2017 at 12:24 PM
    Tacowin1013
    Sorry OP, thats all I got but do post your findings when you get it figured out!
  5. Aug 14, 2017 at 12:25 PM
    17tacosport
    Hasmeet
    Buffalo,NY
    Yeah still waiting on them to respond
  6. Aug 14, 2017 at 1:18 PM
    17tacosport
    Hasmeet
    Buffalo,NY
    They still haven't responded to email or on their lighting thread, this sucks cause everything else got installed easily and this stopped the last bit of work left on the installation
  7. Aug 14, 2017 at 1:21 PM
    trdsupreme
    Hang in there. They just may be busy right now at the moment. They are usually good about getting back within the same day. I feel your pain, man!
  8. Aug 14, 2017 at 1:23 PM
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    time to phone them wires
  9. Aug 14, 2017 at 1:37 PM
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    Looks similar to the wiring harness my LED bar had from CaliRaised. However, it has enough variation that I would email them for confirmation.
    https://www.tacomaworld.com/threads/switch-wiring-help.481521/page-4#post-15801311
    I wasted hours of researching an answer while waiting days for a response from their support email address. I finally did get a response, which was a bit vague. Vagueness and electronics/electricity do not play well together! I replied asking them to give more details and made a guess at what the person may have intended. They replied that my guess at their interpretation was correct. The linked post above is the final, working outcome of all that wasted time, because they don't want to provide accurate and updated documentation for their products. :jerkoff:
    climbhigher23 likes this.
  10. Aug 14, 2017 at 2:18 PM
    17tacosport
    Hasmeet
    Buffalo,NY
    They replied and said the wiring is
    green on switch - red/blue
    red closest to green on switch- blue/yellow
    black on switch - green/yellow
    red closest to black add a fuse
    Tacowin1013 and trdsupreme like this.
  11. Aug 14, 2017 at 2:19 PM
    17tacosport
    Hasmeet
    Buffalo,NY
    Hope this helps someone else down the road!
    Tacowin1013 likes this.
  12. Aug 22, 2017 at 1:29 PM
    TACOsoup
    TACOsoup Well-Known Member
    Levi
    San Antonio, TX
    2017 Quicksand Tacoma TRD Off Road
    OME lift BFG KO2 285/75/16
    Did this work for you? Definitely did not for me.
  13. Aug 22, 2017 at 1:37 PM
    17tacosport
    Hasmeet
    Buffalo,NY
    Yeah it worked perfectly, I was talking to OP and he said it didn't work for him and in a different thread a member was told to do the same configuration from cali raised and it wasn't working for him either. I will try to take a pic of the connections later if it helps anyone
    TACOsoup[QUOTED] likes this.
  14. Aug 22, 2017 at 1:40 PM
    sigrooms
    Sam
    Which did you buy, the bar or ditch lights? Does your wiring match exactly like the above image?
  15. Aug 22, 2017 at 1:42 PM
    TACOsoup
    Levi
    San Antonio, TX
    The side projector ditch lights. Same wires as pictured.
  16. Aug 22, 2017 at 1:50 PM
    sigrooms
    Sam
    Since the above doesn't work for you, it sounds like the harness was connected to the relay differently than expected when manufactured. Without a multi-meter, you would otherwise need to peel back the shrink cover at the relay connection to find which wire is connected to what pin on the relay and which to ground.
    You could also email caliraised for additional assistance. When I received differing colored LED Bar harness wires than what they have documented, I waited to received a reply from them before moving forward.
  17. Aug 25, 2017 at 6:37 PM
    Khayes
    Khayes Active Member
    Morgan Hill
    17 Tacoma sr5 but like a cool one
    I had the same problem with my stuff yesterday after I couldn't find a phone number I emailed them then got impatient and wired it up with the circle switch.
    Then my friend hooked up those beeping stick things said the oem switch didn't even work.
    I'd be extremely pissed but I did a good job of drilling for the circle switch and the lights look great.... but I probably won't buy from them again
    climbhigher23 and Frenchy18 like this.
  18. Aug 25, 2017 at 6:40 PM
    TACOsoup
    Levi
    San Antonio, TX
    I was about to do the same but found a scion switch on Amazon and got it to fit in the blankScreenshot_20170825-204335.jpg spot.
    Khayes[QUOTED] likes this.
  19. Aug 26, 2017 at 3:49 AM
    trdsupreme
    Sounds like an ongoing harness wiring consistency issue.
    Maybe Cali raised can develop a proprietary harness ?
  20. Aug 26, 2017 at 6:28 AM
    17tacosport
    Hasmeet
    Buffalo,NY
    Yeah I feel like besides me no one else is getting this harness to work
