Help with wiring fuse block and switches
Discussion in 'Lighting' started by anthony250f, Oct 15, 2017.
  1. Oct 15, 2017 at 4:33 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Hey guys my head is spinning trying to plan for wiring my lights up.
    I am using a blue sea fuse block. 100amp breaker and 4 carling rocker switches.
    I had planned on running 1 power wire for each switch which would mean running 4 power wires through the firewall and then each acc wire to to the switch.
    Is this the easiest way to do this? I was planning on running 16g wire for the entire thing.
    1 switch will run a 20" led bar and two pods. 2nd switch will be just two pods.3rd switch two pod reverse lights. 4th switch is just 2 super small led strips.
  2. Oct 17, 2017 at 9:11 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    which fuse block? you will still need a relay setup for each light.
  3. Oct 20, 2017 at 7:39 AM
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
