Help with wiring
Discussion in '1st Gen. Tacomas (1995-2004)' started by 981stgentaco, Jun 13, 2023.
  1. Jun 13, 2023 at 10:37 AM
    981stgentaco
    981stgentaco [OP] New Member
    I have a sub that I put in my 98 2.7l and I want to put rock lights and led light pods in and was wondering how I connect it to the battery. Is it ok if the 2 wires touch when they’re connected to the battery since they both are taking power and what would be the most amount of lights I should wire to the battery?
  2. Jul 9, 2023 at 4:19 AM
    TimPall13
    TimPall13 Well-Known Member
    Tim
    Sandy Oregon
    3link SAS 02 SR5 Limited V6
    Lift: TrailGear 3link SAS with Fox 2.0 Coil overs in front. Custom Alcan Leafs with relocated Fox 2.0 shocks in rear. Sitting at 6in of lift. Armor: Relentless Fab Front bumper with home made hoops and Warn VR Evo 10s winch. Relentless Fab Rear bumper with swingout gate. Gears/Grip: 4.88 gears with ARB Air lockers front and rear. 35x12.5 Mickey Thimpson Baja Boss MTs on 17in Trail Ready Beadlock wheels. Lighting: 6000k 55w HID head lights in Retrofit Prejectors, KC Slim Light LEDs behind a Grillcraft grill and on CBI windshield mounts, And LED rock Lights. Performance: 6" deckplate mod, URD Crank Pulley, K&N air filter, ISR mod, and a AirRaid throttle body spacer, magnaflow muffler. Audio: Alpine speakers and sub running on a Alpine 5ch amp. All ran with Stinger wire kit, and a Alpine touch screen reciever. Extras: 15% Window Tint, Spray in bed liner, LineX coated factoey fender flares, Custom Roof rack/Track system, SoftTopper Canopy, Viair Dual 444c Onboard air with dual 2.5Gal tanks.
    Hey, welcome to tacome world!
    Wires stacked on battery isn't necessarily a bad thing but there is always a cleaner and more efficient way of doing it. First off, do you plan on running more lights or electronics in the future? If so, I'd recommend running a fuse block with a single wire from the pos post of battery. Then all your wires would come from that or relays instead of stacking on battery post. Any further questions, feel free to DM me for help or pictures of how I set mine up.
    Tim
    Madjik_Man likes this.
  3. Jul 9, 2023 at 6:32 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    In theory you can hook up as many circuits to the battery as you need to have.
    There are many options to how you may want to wire things.
    Remember to install circuit protection for each circuit .
    How do you plan to control your lights?
