HELP Yellow Wire Mod!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyo freak, May 1, 2010.
  1. May 1, 2010 at 9:12 AM
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Just did the yellow wire mod, cut the second wire, like i was supposed to, but now my maintanance required light keeps flashing!!!:confused:
  2. May 1, 2010 at 9:13 AM
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
  3. May 1, 2010 at 9:19 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    The light flashes for like 5-8 seconds when I start the truck now, never did it before. Is this normal
  4. May 1, 2010 at 9:22 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  5. May 1, 2010 at 9:27 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Could the light be on because I need to change my oil? I have 4,500 miles on it and haven't serviced it yet?
  6. May 1, 2010 at 9:31 AM
    Andy2010
    Andy2010 Well-Known Member
    Andy
    Bucks County, Pa
    2010 TRD Sport Mag Grey 4x4
    EGR inline vent visors, Trimmed front mud flaps, Hose clamp mod, AFE Pro-Dry S air filter, Bed mat off my '97, 5100's up front @1.75, Rear TSB, Tow package, Black TRD center caps, Weathertech Digitals, Wet Okole's in front
    Wow, dealer had me come back at 1,000 miles for a free oil change.
  7. May 1, 2010 at 9:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes.
  8. May 1, 2010 at 9:39 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Yea need to get oil change, it just freaked me out when it came on not long after i cut the wire and hooked battery back up!
    Thanks Guys
    :facepalm:
  9. Apr 15, 2011 at 12:59 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Another yellow wire mod help before I cut the wire on my 2010 reg cab 4x4, I want to make sure I'm doing it correctly. Here's a pic I just took. Do I cut the yellow wire that is second from the top here (where I'm pointing)?
    Click for full-size image (1024 x 768)
    I'm going wheeling tomorrow and wont have a bunch of time to fix things if this messes everything up. Here are the steps I'm going to do: 1. Disconnect the battery 2. Unplug that clip with all the wires going into it 3. Cut the yellow wire second down from the top 4. Connect clip back in 5. Connect battery
    Is this correct? What if I dont unplug the white clip with all the wires going into it before I cut the yellow wire?
    Thanks guys!
  10. Apr 15, 2011 at 1:01 PM
    Nonfatwater7
    Nonfatwater7 Well-Known Member
    Missoula, MT
    06 DC LB 4x4 Indigo
    Map Light mod, 265/70/17 BFG AT's, 5100's front set at .85, Eibach coils, Hi-lift bed rail mount, CB radio, Sway bar removed, 886 reverse light mod, LED tail lights and blinkers, Wickedflows exhaust, $4 aux/ipod input mod
    What is the yellow wire mod?
  11. Apr 15, 2011 at 1:02 PM
    especk
    Erik
    Redding, CA
  12. Apr 15, 2011 at 1:04 PM
    Nonfatwater7
    Missoula, MT
    06 DC LB 4x4 Indigo
  13. Apr 15, 2011 at 1:14 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Hey man, I can't help you with the yellow wire mod because I haven't done it.
    But - I can offer a word of perspective: A time when you "won't have a bunch of time to fix things if this messes everything up." is a *bad* time to be making a modification. :eek:
    Just sign me: a guy who has previously exercised bad timing. :D
  14. Apr 15, 2011 at 3:27 PM
    especk
    Erik
    Redding, CA
    Good call. I'll just wait until a get back from Cleghorn to do it. I wanted to do it before I go so I can try it out, but it may be too risky. Thanks.
