Help?!?!?!
Discussion in 'Suspension' started by camh, Aug 13, 2010.
  1. Aug 13, 2010 at 2:09 PM
    camh
    camh [OP] Member
    Cam
    D.C
    05 SR5
    I recently got my 05 tacoma and it has 60,000 with miles original tires.
    I really would like to upgrade with much bigger tires..possibly 33's but am lost in the search!
    I have also read that for bigger tires i would need a lift of some sort but could use advice on what size to get so i could run bigger tires.
    Any help would be greatly appreciated!
  2. Aug 13, 2010 at 3:25 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    you will want to get 285/70/R17 most likely. There are lots of popular brands to choose from. You will want to go with atleast 2.5" of front lift to fit these tires. I would suggest the billy 5100's set at 2.5" for your most economical solution with a 1.5 or 2" AAL in the real. Or if you want to spend the money the OME setup with 885 springs and an AAL is always a good choice. check with www.toyteclifts.com or or wheelers for prices on these setups.
  3. Aug 13, 2010 at 3:53 PM
    camh
    camh [OP] Member
    Cam
    D.C
    05 SR5
    thnx I FOR SURE WANT TO RUN A 3IN LIFT WITH 285.. I just need to find a good lift...for the OME what would be the best choice for the rear setup?? if i order 885 in the front??
  4. Aug 13, 2010 at 3:56 PM
    PreRunnerSeth
    Apex, NC
    cant go wrong with the billies with a 1/2" spacer to achieve 3" total or the OME kit. Just remember that 3" youre pushing the ball joint angles. I highly suggest the Total Chaos UCAs. The LR's are an attractive option as well, but my experience from installing a few of these, is that they tend to hit the coil at full droop. The LRs have a large grease boot on them. If you can swing it, I would go with the total chaos.
