HELP
Discussion in 'Lighting' started by stunt man hans, Dec 24, 2010.
  1. Dec 24, 2010 at 1:23 PM
    stunt man hans
    stunt man hans [OP] DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    WHICH IS THE POWER WIRE ON OUR CORNER LIGHTS OR PARKING LIGHTS? IS IT THE GREEN OR THE WHITE on the passenger side?
  2. Dec 24, 2010 at 1:25 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    green.
    also your caps lock is on.
  3. Dec 24, 2010 at 1:33 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    sorry i noticed after posting. i'm hooking up the leds in my retrofit and the drivers side works fine. the passenger side does not do i need to run the positive wire over to the drivers side? the only reason i ask is because the green wire on the drivers side feels thicker and when you pull it out of the wire loom its purple not green? idk wtf this was my christmas present and now it looks retarded. any advice would probably help as i'm stuck in a big way.
  4. Dec 24, 2010 at 1:35 PM
    CopDoctor
    08 335i
    nah you should be able to use the green on passenger side as well. re-tap it and make sure everything is connected correctly.
