help!
Discussion in '4 Cylinder' started by stephan305, Dec 31, 2010.
  1. Dec 31, 2010 at 9:31 AM
    stephan305
    stephan305 [OP] Active Member
    stephan
    miami,fl
    1999 prerunner
    2 1/2 skyjacker lift k/n cold air filter
    i had my 99 prerunner 2.7 transmission flushed and refilled.BUT the shop put to much fluid back in.i have been driving for about 20.000mile before i seen fluid drops on my driveway.i drained the pan and added 14oz trans honey and one full quart fluid.i am not sure about the level because whats in the tube.will that be enough to be safe for the transmission?thank you:confused:
  2. Dec 31, 2010 at 9:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Ummm.....I dont think you should have added the "Trans Honey". You need to take it someplace and have the level checked. Drips from the tranny are useually indicative of a leak from someplace.
