HELP !
Discussion in 'Technical Chat' started by cd2cd2, Sep 25, 2011.
  1. Sep 25, 2011 at 3:54 PM
    cd2cd2
    cd2cd2 [OP] Member
    C.D.
    va
    2005 tacoma 4x4 v6
    I just purchased a 05 tacoma v6 with air bag suspension. It has an valve stem behind rear lic. plate. How much air pressure should I keep [max]-[min]?
  2. Sep 26, 2011 at 3:45 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    I would ask the previous owner or go to the air bag website. Does it ride OK now?
    I am sure the manufacturer can give you some general PSI.
    Had height adjustable shocks on a 69 Camero(about 100 years ago),
    Just depended on how stiff or spongy you wanted the ride.
  3. Sep 26, 2011 at 3:48 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    15-50 psi. (it is rated to 100 but NEVER inflate it that high) I found that 20 was good for everyday driving and the most I ever had them at was 45 psi with a super heavy load for a Baja camping trip. Mine was an '05... is the truck silver?
    Oh, I see you say just one valve... Mine had seperate air valves on each side of the license plate.
  4. Sep 26, 2011 at 3:56 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Googled
    "Auto air bag suspension recommended PSI"
    Should get you the info your looking for.
  5. Sep 26, 2011 at 10:57 PM
    David K
    I already gave him a range... as it sounds like he had the same set up as I did (RideRite).
  6. Sep 27, 2011 at 1:09 PM
    cd2cd2
    cd2cd2 [OP] Member
    C.D.
    va
    2005 tacoma 4x4 v6
    I've been ride'n with 20 psi & it rides pretty good thanx again
  7. Sep 27, 2011 at 4:35 PM
    David K
    Excellent... and when you load up the truck... just add air to level it... 35-45 psi may be fine!
