Help!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by homelandtaco, Nov 2, 2011.
  1. Nov 2, 2011 at 5:52 PM
    homelandtaco
    homelandtaco [OP] Member
    Tyler
    Riverside, CA
    02 DoubleCab SR5, Icon Coilovers
    Icon 2.5 Coilovers, Pro Comp AAL, Rear Bilstein 660's, Deck PLate Mod, Flowmaster
    I have a 02 pre runner double cab 3.4 v6 with 146,000 mi on it. Was messing around in front of my buddies house yesterday and reved it up an after I reved it up it just died then wouldn't start back up. After a few trys I got
    It started and it seemed to run fine then when I went to take
    Off and put it in gear it spudderd a little and almost died. The cel isn't on and I don't know where to start Im pretty sure it's a sensor but not sure which one.. Any help or suggestions would be
    Much appreciated.:confused:
  2. Nov 2, 2011 at 5:56 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    not a clue. sub'd
  3. Nov 2, 2011 at 6:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    See if the issue clears up. With no CEL, its hard to make an accurate guess.
  4. Nov 2, 2011 at 6:08 PM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    How high did you rev it?
  5. Nov 2, 2011 at 6:18 PM
    homelandtaco
    Tyler
    Riverside, CA
    Right around 5,000 but I have reved it up like that before and it has never done anything like that, and just pulling out Of my driveway today It died when I just gave it a little gas to pull out.. Idk it's driving me nuts thinking about it and not being able to figure it out
  6. Nov 2, 2011 at 6:24 PM
    homelandtaco
    Tyler
    Riverside, CA
    I'll try that plugs are cheap compared to all the sensors I couldn't believe how much all the sensors are.. What kind of plugs did u use? I heard iridium plugs don't work good in toyota's?
  7. Nov 2, 2011 at 6:26 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    id check the mass air flow sensor and check to make sure you dont have a sticky idle air control
  8. Nov 2, 2011 at 6:29 PM
    homelandtaco
    Tyler
    Riverside, CA
    I did clean the MAF I heard about the idle control sensor doing that. Do u just use throttle body cleaner to clean that?
  9. Nov 2, 2011 at 6:31 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    first the easiest way to check it is keep your foot down on the gas and see if it dies, if you let go and it does it very well may be your IAC, id honestly get a tooth brush and rags and clean it with MAF cleaner or brake cleaner, but be wary of brake cleaner and plastic or sensors
  10. Nov 2, 2011 at 6:35 PM
    homelandtaco
    Tyler
    Riverside, CA
    Cool thanks man I will get that tomorrow and try that I'll keep you posted on the results.
