help!
Discussion in 'Suspension' started by blueNCtaco, Nov 13, 2011.
  1. Nov 13, 2011 at 11:07 PM
    blueNCtaco
    blueNCtaco [OP] Member
    patrick
    NORCAR
    07 4x4 swb sport
    I know everyone is gonna hate on me, but im getting a spacer lift cuz im short on money right now. But i was just wonderin if the differential drop lit is nessersary for 3in spacers?
  2. Nov 13, 2011 at 11:08 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    diff drops are pretty much ineffective on 2nd gens, IIRC. Look into the boot slide mod for 2nd gens instead
  3. Nov 13, 2011 at 11:25 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    next time OP, make a title that's more descriptive to your situation-
    "Do I need a diff drop w/ a 3" lift?"
    or
    "Is a diff drop needed with this lift?"
    would be more appropriate :thumbsup:
    The only threads titled "help" should be for OP's in bad/ emergency-ish situations, like being stuck on a trail with nobody around
  4. Nov 14, 2011 at 12:11 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    If you are short on money, then skip the lift, especially since you're doing a 3in spacer. You're going to end up doing more harm than good. Save up $200 and get the Bilstein 5100 replacement struts (front only). You'll get 3in of reliable lift. There was a thread here where another member ran a 3in spacer and it eventually snapped his OEM strut.
    You can still throw block in the rear to level it out, but upgrade that to an AAL eventually.
    http://downsouthmotorsports.com/i-1...pre-runner-4wd-front-pre-load-adjustable.html
  5. Nov 14, 2011 at 5:39 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Another vote for no spacers, and going with 5100's instead.
    Spacers will just cause you more pain, and cost you more money in repairs down the road.
    $200 for 5100's and another $80 for an AAL and you're set.
    Fink
  6. Nov 14, 2011 at 7:32 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    OP's future
