HELP!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04trd4x4AL, Jan 2, 2012.
  1. Jan 2, 2012 at 12:20 PM
    04trd4x4AL
    04trd4x4AL [OP] Well-Known Member
    Daniel
    New Market AL
    04trdDBLcab4x4
    Tint , Deck Plate, debadged, Bil 5100's set @ 2.5 up front, Bil 5100 in the rear and AAL. Diff drop. B.A.M.F brake proportioning bracket.
    Ok guys some of you may have read this in the "What have you done" post. But here is the problem. Took truck to Advance Auto and had the cpu read. It didnt give a code just a Bank 1 running lean. Do they know how to really read these things. Researched a little. Found a couple of things, So far I have cleaned the Throttle body. Want to clean the MAF but sorry don't really know where that is. Looked at the connections of the 02 upstream sensor, blew them off. Cranked truck up ran for 5 min. Every time I start it up, it idle's like I got a huge cam in it. Then after about a 20 seconds of doing that is comes back up to normal idle.
  2. Jan 2, 2012 at 12:26 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    maybe someone can post a pic of the maf up here, what code was it? it sounds like a bad MAF
    edit. on your truck iirc its on the air intake close to the filter and has a few wires and 2 screws holding it in
  3. Jan 2, 2012 at 1:00 PM
    IllinoisTaco
    IllinoisTaco Active Member
    Illinois
    2002 Toyota Tacoma 4x4 SR5
    Here you go
    it shows where it is in the picture. I assume you have the 3.4? Here is the rest of the manual.. It was posted in the DIY sticky
  4. Jan 2, 2012 at 1:08 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    With the truck idling take the handle of a screw driver and lightly tap the MAF sensor; if the idle changes you need a new (or rebuilt) MAF sensor.
  5. Jan 2, 2012 at 1:31 PM
    04trd4x4AL
    Daniel
    New Market AL
    04trdDBLcab4x4
    Ok thanks guys. Took it out cleaned it, reset cpu and it still doing it. UGH!!!! I think Im gonna try some seafom!!
