Discussion in 'Audio & Video' started by hard2kill, Mar 14, 2012.
  1. Mar 14, 2012 at 5:06 AM
    hard2kill
    hard2kill [OP] Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    I installed my new kenwood headunit last night and everything works great but now my gauge cluster doesn't light up ? My seatbelt,tpms,highbeam and all warning lights work but the gauges don't light up... Any ideas?
  2. Mar 14, 2012 at 7:25 AM
    sun
    sun Well-Known Member
    Memphis
    2011 PreRunner
    Pioneer avic-z130bt with axxess aswc and rear cam mod, audiovox 10 flip down monitor, Pyle pl76d headrest monitors, kicker cvr tens wired down to one ohm with hifonics Brutus 1200.1, Clazzio seat covers, 20% tint on front windows, polished factory exhaust, peragon retractable bed cover, pop n lock tailgate handle with dei actuators for automatic lock, viper 5901 alarm remote start with viper smart start, hid bixenon 4500k headlights with 4500k fog lights, led map license plate lights and dome lights
    Not trying to sound like a douche or anything but did u make sure ur dimmer isn't turned all the way down? And have u checked fuses?
  3. Mar 14, 2012 at 7:40 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    ^ There's nothing wrong with that question, sometimes I forget to check things like that.
    Did you tap any wires when you installed the radio for lights or anything?
    Also, make sure you didn't pull any plugs loose or pop a wire out of a harness when you installed the new head unit. I know a lot of aftermarket nav units are longer/bigger than the stock unit so you might have pulled something loose that knocked the lights out.
  4. Mar 14, 2012 at 10:56 AM
    hard2kill
    Rhinebeck NY
    I checked the dimmer..it's just a standard kenwood single din headunit... The fuse under steering wheel marked gauges is fine.... I'm gonna have to pull it back apart :(. I find it weird that all the little lights like the seatbelt light still work just not actual gauge lights...
    Only other thing is I didn't buy the steering wheel control adapter cause I never use them so that plug is hanging out in the dash... Lots of guys don't buy the adapter though an don't have problems... I hate electronics but have installed many quality systems in various cars over the years :/ never seen something like this'd happen
  5. Mar 14, 2012 at 11:32 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Did you tape up the wires that weren't used? As far as I know there is no dimming function on the kenwood hu, mine doesn't have it, and I shorted out my rheostat trying to make it dim.
  6. Mar 14, 2012 at 1:25 PM
    hard2kill
    Rhinebeck NY
    What happened when u shorted it out?
  7. Mar 14, 2012 at 5:08 PM
    hard2kill
    Rhinebeck NY
    So I checked fuses took it all back out and hooked up stock deck and nothing lights still don't work :(. I felt around for loose wires or plugs and couldn't find anything ..... I'm stomped? The gauges still work but the lights don't... The dimmer still works the climate control lights.. And the lil warning lights in the dash still work ?????
  8. Mar 14, 2012 at 5:17 PM
    Warhorseforever
    Will
    Sand Lapper
    Did you check fuses under the hood? There may be something there but I'm sort of lost now to be honest. maybe you fried something behind the dash or for some reason just poped all the bulbs.
  9. Mar 14, 2012 at 6:54 PM
    hard2kill
    Rhinebeck NY
    Yup checked fuses all over
  10. Mar 15, 2012 at 2:08 PM
    hard2kill
    Rhinebeck NY
    Me other ideas guys?
