HELP!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AK Toy, Apr 5, 2012.
  1. Apr 5, 2012 at 8:50 PM
    AK Toy
    AK Toy [OP] Well-Known Member
    spider headlights, coustom bumper, tires, paint, CB W/ PA, throttle body spacer, air intake, exhaust
    my yota just took a dump there is no power what so ever. i tryed jump starting.. checked terminals.. and push starting (its a manual) and nadda. any suggestions??
  2. Apr 5, 2012 at 8:51 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    :notsure:Put some gas in it
  3. Apr 5, 2012 at 8:53 PM
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
    IS IT TURNING OVER? SOUNDS LIKE YOUR ALTERNATOR MIGHT BE GOING OUT IF NOTHINGS HAPPENING
  4. Apr 5, 2012 at 8:54 PM
    MonkeyProof
    SoCal- SGV
    Check the battery cables to ensure they are properly tight on the terminals and that there is no corrosion on the terminals
  5. Apr 5, 2012 at 8:57 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Check fuses and various wires.
  6. Apr 5, 2012 at 9:11 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    What are the specs on your truck? Year, model, mileage?
    Any recent mods? (Goes towards cause of failure)
    Check the big ones first: Fuses, grounds, alternator, etc.
  7. Apr 5, 2012 at 9:32 PM
    AK Toy
    its a 2005 toyota tacoma sport it seems like the bat. will charge up then go to crank and all the power that was charged up from the jumper truck is gone i do have a aftermarket sterio and fogs on there but, my thoughs are even if the bat. is dead shouldent i still be able to start it by throwin it in to gear
  8. Apr 5, 2012 at 9:34 PM
    LAoffroadin
    Joshua
    Northwest
    2012 offroad 4x4
    YES SEEMS LIKE A WIRING PROB.
  9. Apr 5, 2012 at 9:39 PM
    1980 Well-Known Member
    The Dust Bowl
    If your battery won't hold a charge and is over four years old it it probably dropped a plate and is toast. Get a new battery and see what happens.
    Remember that a gas truck with an alternator requires some battery power to run at all, unlike a diesel that will keep running without a battery if you can get it started.
    As another poster said -- check fuses and trace the wires -- it may be as simple as a wire that has come loose. Also, clean your battery terminals.
    If you get a new battery and still can't start it or even push start it then it's time to get your ignition system checked.
    Edit: Being able to keep running if the charging system fails is why small plane engines have magnetos.
  10. Apr 5, 2012 at 9:39 PM
    AK Toy
    wireing has been done for over a year, im sure if it was that it woulda happened sooner
  11. Apr 5, 2012 at 9:43 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Sometimes things come loose.
  12. Apr 5, 2012 at 9:54 PM
    AK Toy
    true, well thank you guys! i will check and doubble check wires and check the bat. but i have a feeling its my alt.
  13. Apr 5, 2012 at 10:11 PM
    Bishop2Queens6
    SoCal
    2009 DCSB MGM
    Get your battery tested, but if you're still on the OEM battery, that's pretty much gone so get a new one. If you're battery is good (which I doubt), replace your alternator.
  14. Apr 5, 2012 at 10:11 PM
    LAoffroadin
    Joshua
    Northwest
    2012 offroad 4x4
    I HOPE THATS IT MAN YEAH ALT, WAS MY FIRST THOUGHT FROM WHAT YOU WERE SAYING....
  15. Apr 6, 2012 at 6:14 AM
    D4D Hilux Dude
    D4D Hilux Dude Well-Known Member
    Darren
    Washington, DC
    2011 4x4 Double Cab TRD Offroad
    TRD Supercharger TRD Catback Exhaust Ziebart Rust Proofing Additional Bed Ties
    Sounds like the alternator.
    is this true? My gas cars could run without the battery once started....
    Hmmm....
  16. Apr 6, 2012 at 6:32 AM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    Sort of. You have to have a battery with the internal circuits in place for the vehicle to run even if the alternator is fine. The Toyota battery seems like a long lasting battery, except when it dies it's often due to a plate falling or internal connection breaking.
    In my '07 one day ~2 years ago, cranked up fine at the house then drove to the gas station about 2 miles away. Pulled into the station, everything fine and normal. Filled up w/ gas, went to crank - battery dead as a hammer, internal plate failure. Putting jumper cables across would allow the starter to turn the motor, but it wouldn't crank or run.
    The POS battery I stuck in there because I was in a bind and it was all I could find on a Sunday afternoon went bad a few weeks ago. It didn't shit it's internals just typical sulfation you expect with a bad battery. It could be jumped off and driven anywhere as long as the motor wasn't shut off.
    It depends on what caused the battery failure - Toyota batteries seem to destroy their internals when they die fairly frequently, which usually will prevent them from being jumped/push started.
    David
  17. Apr 14, 2012 at 10:05 AM
    AK Toy
    got her up and goin it was a bad battery ground to frame
  18. Apr 14, 2012 at 10:24 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Sometimes you never expect the GROUND--ITS IMPORTANT!!!!!!!!!!!!!!
