HELP!
Discussion in 'Lighting' started by Rellik01, Apr 20, 2012.
  1. Apr 20, 2012 at 2:47 AM
    Rellik01
    Rellik01 [OP] Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Tail lights don't work (brake lights ok) Switches on dash as well as a/c cluster also not working. Speed, RPM are lighted as normal. Also when exiting vehicle headlights don't auto shut off as they used to. I checked all the fuses, any suggestions. Could it be a relay and if so which one. Trying to save a tripto the dealer.
  2. Apr 20, 2012 at 2:49 AM
    Rellik01
    Craig
    Windermere, Florida
  3. Apr 20, 2012 at 1:01 PM
    Rellik01
    Craig
    Windermere, Florida
    Got bad vibes on this one just checked the 10a fuse under the kick panel and found it all melted. Cant't even replace fuse as the receptacle is distorted. Probably need new fuse box at the least Dash lit up like a Christmas tree. Have a feeling dealer will somehow blame me. sick to my stomach over this. It seems to be getting progressively worse. Anyone experience something similar? and what was the outcome.
  4. Apr 20, 2012 at 1:15 PM
    berg2065
    berg2065 Well-Known Member
    Phoenix
    11 reg cab 4x4
    5100's set at .85,eibachs, LR uca's, toytec 1.5" aal, ride rite bags, receiver hitch, ARE cap with bedrug, Thule rack, wet-okole cover, ultragauge, kenwood dnx5180 navi/receiver, ss rubi404 running factory doors and JL8
    I have never had the type of issue you are dealing with. But before you take it to the dealer, you may want to remove any aftermarket lighting from the truck.
    Good luck
  5. Apr 20, 2012 at 3:04 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    What aftermarket equipment do you have hooked up? Sounds like you have something hooked up directly to that circuit instead of thru the battery/relay that melted the wiring/block.
  6. Apr 20, 2012 at 5:19 PM
    Rellik01
    Craig
    Windermere, Florida
    nothing on that circuit. I suspect a short somewhere in the tail light system. I have feeling this is gonna cost me. Thanks
  7. Apr 21, 2012 at 12:24 PM
    t_e
    Erik
    miami,fl
    Not on that circuit but sounds like you have something hooked up pulling power that ultimately feeds the tail lamp/gauge lighting circuit that melted the wiring going into the fuse block.
  8. Apr 21, 2012 at 12:28 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    You have a warranty. Why on earth are you screwing with it, all you're going to do is give them a reason to not touch it.
  9. Apr 24, 2012 at 10:30 PM
    Rellik01
    Craig
    Windermere, Florida
    Traded it in for a 2012 trd sport SB 4x4. Once you have electrical problems they are with you for life. got great price on new truck and good price on limping trade.
  10. Apr 24, 2012 at 10:31 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    Like that. Fuck a broken truck just pick up a new one :D
    Haha nice new rig
  11. Apr 25, 2012 at 6:22 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Not bad. :D
