help
Discussion in 'Wheels & Tires' started by Dillan12, Feb 26, 2013.
  1. Feb 26, 2013 at 2:17 PM
    Dillan12
    Dillan12 [OP] Member
    dillan
    alabama
    05 toyota tacoma 4x4 sr5
    3in lift
    But if its a unalversu r how ever u spell it lol. It should work right
  2. Feb 26, 2013 at 2:18 PM
    Dillan12
    dillan
    alabama
    3in lift
    But what if it a unanveral r however u spell it it should work right
  3. Feb 26, 2013 at 2:27 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Nope, aftermarket wheels are not universal. If that info is wrong they might fit, or if the guy you are buying from bought the wheels with a 106mm hub bore or more and used hub centric rings for some reason they could fit. I highly doubt it tho, you wont even be able to get the wheels on
  4. Feb 26, 2013 at 2:28 PM
    Dillan12
    dillan
    alabama
    3in lift
    Ok thanks
  5. Feb 26, 2013 at 4:54 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    No problem. Look on the bright side, now you can get 18s cuz 20s look to big for tacomas :p good luck man
  6. Feb 26, 2013 at 8:20 PM
    Dillan12
    dillan
    alabama
    3in lift
    Ok let me ask this if the center bore in the rim smaller can I put wheel spacers on to bring it out past the the center hub
  7. Feb 27, 2013 at 2:01 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Good question, i think that might work. Only issue is pushing the wheel out to much will increase the rubbing on the fenders and cab mount, but you dont even know the offset/backspacing yet.
    Can anyone else confirm this?
