Discussion in 'Solid Axle Suspension' started by clawn1956, May 22, 2013.
  1. May 22, 2013 at 12:07 PM
    clawn1956
    clawn1956 [OP] New Member
    04 Pre-runner
    How hard is it to replace right rear axle seal? I have fluid leaking onto garage floor. Do you any special tools?
  2. May 22, 2013 at 5:15 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Easy if you have any mechanical ability at all. If your leaking gear oil all over the place (inside of the tire, brakes) your wheel bearing is bad and you need to change that too.
