HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ksmoove757, Sep 26, 2013.
  1. Sep 26, 2013 at 4:44 AM
    ksmoove757
    ksmoove757 [OP] Well-Known Member
    Kenneth
    VA BEACH
    2012 Tacoma Sport 4x4
    My current setup are the 5100s all around with 1 inch rear block. I have the front set to the highest level and I'm running 285/70r17 terra grapplers with the stock sport rims and 1 inch wheel spacers. I balanced and aligned all the tires but I'm still getting a slight vibration in my steering wheel. Will aftermarket rims solve the slight vibrations I'm getting?
    Thanks
  2. Sep 26, 2013 at 5:14 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Its either your u-joints need replacing or you need a carrier bearing drop. Streetacos.com sells them. I needed both to fix my issues
  3. Sep 26, 2013 at 9:23 PM
    ksmoove757
    Kenneth
    VA BEACH
