HELP!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by kanoaml, May 14, 2016.
  1. May 14, 2016 at 3:48 PM
    kanoaml
    kanoaml [OP] Well-Known Member
    2001 Toyota Tacoma
    I have a 2001 Pre-runner, 4door, V6, automatic 2WD. I ordered a 3" lift but am wondering about wheels and tires!
    Option one: 16x8, 4.5 BS, 0+ offset.
    Option two: 16x8, 4 BS, -12 Offset
    I like option one better but I want to run 285/75 on them. Would it clear frame, UCA, etc. and only require plastic trimming? Or would they hit the frame when turning and stuff? If so, I'll go with rim two. Thanks!
  2. May 14, 2016 at 7:39 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    With our trucks, running 285/75/16 you will need at least 4" of backspacing to clear the uca. You will still rub the pinch weld as well with up travel of the suspension. Easy fix though with a 3 Pound sledge:D
    kanoaml[OP] likes this.
  3. May 14, 2016 at 7:47 PM
    kanoaml
    2001 Toyota Tacoma
    Pinch weld refers to the frame? What if I ran 275/70 on the 16x8 4" BS 0+ offset? Would that clear everything?
    Is there such thing as 275/75/16? If so would that clear?
  4. May 14, 2016 at 7:52 PM
    FirstGen Jer
    Jeromey
    Sorry I only have experience with running 265/75 and 285/75. The pinch weld is on the back of the wheel well behind the tire by the mud flap. Do a quick search of "pinch weld mod "and you will see what I'm talking about. Easy fix.
  5. May 14, 2016 at 8:55 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Thought this was an emergency. Was just another wheel/tire thread where the info they need would have been easily found by searching.
    bry838 and Delta00 like this.
