Help!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by I am the quench, Dec 26, 2016.
  1. Dec 26, 2016 at 11:34 PM
    I am the quench
    I am the quench [OP] Member
    Sebi
    Florida
    01 double cab prerunner
    Bilstein lift, 1.5'' blocks in the read, bull bar and fog lights
    So Tacoma World, I am in need of advice. I recently converted my 01 double cab to a 4x4 5 speed (Well not entirely 4x4, all I've got for the moment is the transfer case) and its amazing, super fun to drive! However........ At 700-900 RPM my whole car is shuddering, disappears as soon as I give it gas (doesn't matter if I'm driving or standing still, doesn't matter which gear I'm in either as long as the engine hits that rpm range the car shudders) I am pretty confident it is my rear transmission mount. The thing is super busted up and it's only being held in by two of the four bolts (Would take too long to explain why), I'm gonna run some ratchet straps around it tomorrow to help hold it down until the new mount is in. Would you guys say its ok to drive it for another week or two until the mount comes in, or will I destroy my car. Thanks!
  2. Dec 27, 2016 at 12:03 AM
    02YotaGuy
    02YotaGuy Guy With A Red 80 Series
    Matthew
    Springfield, VA
    94 FZJ80
    Bumper, Winch, 315s, Sliders, OME HD lift, Custom rear swingout, roof rack, drawers, way too much to list.
    I'm fairly certain that every mechanic would suggest you park it until it can be properly repaired.
    Tacofart likes this.
  3. Dec 27, 2016 at 12:48 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It is after all your vehicle .
    If there is no other way for you to get around like to work one does what one needs to do..
    As nylon does tend to stretch the cheaper straps even more so .
    As long as you keep checking the tension of the strap the worse that can happen is the mount fails the bolts vibrate out and things bounce around enough to bend the driveshaft maybe the front shaft of the transmission.
    On the bright side it should not fall out completely
  4. Dec 27, 2016 at 6:31 AM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    At the risk of really messing things up I say park it too. It bad right now, but it could get a lot worse.
    On the plus side, you've got a good idea of what needs to be done
    You may want to put some more info in your thread title. "Help!!" Implies you're trapped under your truck, "truck shudders at 700 rpm no matter what, HELP!!" will probably get more clicks
  5. Dec 27, 2016 at 9:00 AM
    I am the quench
    Sebi
    Florida
    Alright thank you guys. I go back to school in two weeks so i'm really hoping the mount gets here in time. Thank you!
  6. Dec 27, 2016 at 9:09 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Sitting still in neutral? Trans mount will not cause what your describing. Did this all start when you did the conversion?
  7. Jan 20, 2017 at 10:26 PM
    I am the quench
    Sebi
    Florida
    The new transmission mount came in, got it installed and the truck is no longer vibrating like a massage chair. Thank you guys
  8. Jan 20, 2017 at 10:42 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    You're welcome. Glad to help
