Truck will not start after dead battery/jump
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Azntaco2025, May 5, 2025 at 5:56 PM.
  1. May 5, 2025 at 5:56 PM
    Azntaco2025
    Azntaco2025 [OP] New Member
    Monday
    2018 trdoffrd
    Help!!! Got a 2018 tacoma. Truck would not crank this morning. My buddy jumped it off and the horn started going off. Got a new battery and truck will not read the key. Have to start it with the key fob next to the button. After start up I have no functions in the truck. No windows, radio, ac. Truck will not shift into gear. Check engine light, abs light, traction, all the damn lights are on light a Christmas tree. Getting messages also about check abs system, check vehicle stability system, check brake system, lane departure malfunction alert see dealer, pre collision malfunction, brake override malfunction. Checked fuses and relay. Brake lights are coming on when pressing the brake. I'm baffled
  2. May 5, 2025 at 6:06 PM
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    Make sure the battery connections are clean and tight. Might be an alternator issue.
  3. May 5, 2025 at 6:11 PM
    Bishop84
    Bishop84 Well-Known Member
    Horn going off means it was backwards boosted, a main line fuse has burnt and requires a technician to replace.
    it’s not a typical diy fuse. It’s bolted inside the junction box
    b_r_o, BillF1564, jmneill and 6 others like this.
  4. May 5, 2025 at 6:12 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    He didn't accidentally reverse polarity jump start it did he?
    Since you can't shift out of park let's start with that since it's the simplest, you have 3 fuses to check there. We know the STOP Fuse is good since the brake lights work but you need to check the ECU-IG No1 Fuse (7.5A) and SFT LOCK-ACC Fuse (5A) in the interior fuse box.
  5. May 5, 2025 at 6:15 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    EDIT: well done changing the title brother. :fistbump:
    Change the tittle to starting issues or whatever. HELP!!! And stuff like that is reserved for stranded folks in the middle of nowhere. Cheers
  6. May 5, 2025 at 6:33 PM
    21TRDPro
    21TRDPro Well-Known Member
    2021 Tacoma TRDPro
    Agree on the string title - you will end up frustrated.
    As for the issue, I am not a technician but I have heard and read that unless you get your connectors back on quickly with a clean connection when changing the battery you can mess up the PCM. Sounds like this might be the issue. If so you need to have your PCM reset. Perhaps someone on this thread knows more and how to go about resetting PCM. Hope this helps.
  7. May 5, 2025 at 6:36 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Oh the advantages of modern timesaving technology!!
    What I have learned from TW is that one should not mess with ANYTHING electrical.
    kahanabob likes this.
  8. May 5, 2025 at 8:23 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    ? ? Changing the battery can mess up the PCM? Resetting the ECU or PCM is done by -disconnecting- the battery, so putting in a new battery would have reset things. (Google it.)
    Just to be sure, disconnect the new battery, wait 15-20 minutes, and re-connect.
    If things are still messed up, it may have been something from the jump start. Start checking fuses as the others advised.
  9. May 5, 2025 at 9:20 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    If indeed the jumpstart was connected backwards who knows what you burned out. Don’t want to scare you but I had a friend do this once on an older car and it blew everything on that car I’m talking every single bulb all fuses hell it even blew out the radio. Hopefully like @Bishop84 has mentioned it only blew a main line fuse.
    musicisevil likes this.
  10. May 5, 2025 at 10:03 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Saw someone hookup cables backwards once. The plastic sheathing fell off, so quick, and immediately the bare cables started dropping through anything plastic they were laying on. Pretty sure both batteries were toasted, and one of those vehicles has those “gremlin” problems.
  11. May 5, 2025 at 10:48 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    I will be the punching bag for the others who help by me not helping right at this moment. For the future buy a NOCO GB40 to boost your truck by yourself wherever you are with just the boost-block. Also it has far fewer reports of shorting out the truck being brought back to life.
    MagicToolbox and Chew like this.
  12. May 6, 2025 at 12:14 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    That noco fried my steering angle sensor, had to replace the clock spring. Not a cheap part but cheaper doing it yourself. I took the noco out after that
  13. May 6, 2025 at 6:14 AM
    Bishop84
    we see steering angle sensors die from repeated boosts, not just noco units. It sucks
    RustyGreen and musicisevil like this.
  14. May 6, 2025 at 10:17 AM
    baldbeardedtaco
    FL
    When you say repeated boosts do you mean multiple attempts to jump or multiple incidents from different customers? So not just noco all types of those jump pack styles potentially or both jump packs and jumper cables w/ donor vehicles?
    the only thing I could come up with was as it was jumped with that noco if there was a voltage spike or something like that and that was the ultimate cause
  15. May 6, 2025 at 10:30 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I doubt it's any fault of the jump pack, modern vehicle electronics don't take kindly to voltage drops and/or spikes which tend to happen with a weak/dead battery and/or jumpstart. Best case everything is fine or you just set a bunch of codes that have to be cleared, worst case you fry one or more modules.
    I don't even unhook the battery on some of this new stuff without reading service info because you don't know what might brick or need to be relearned after if you don't follow it.
  16. May 6, 2025 at 3:11 PM
    baldbeardedtaco
    FL
    I understand we have more and more electronics in vehicles as each yr passes. If we have the possibility of frying something just by jump starting that is a problem- and like I said in my case it was the noco, so now it’s dead to me. That thought will only disappear if I have to jump w/ a donor and cables and I get the same effects.
    I’ll also wait until bishop84 expands on his post because it sounds like he sees it quite often with jump packs. I know what he does so his voice holds a bit more weight
    I have never had issues or worries unhooking a battery to install something and hooking it back up other than the 1 annoyance of the beatsonic front cam glitching and loses both front and rear video- have to do the sequence of direct radio to rear than I can add the beatsonic module and add front and rear. I say it everytime messing w/ batteries … black is 1st (off), and black is last (on)
  17. May 6, 2025 at 7:52 PM
    Azntaco2025
    Monday
    2018 trdoffrd
    Thank you guys for your help. Even got a scanner to hook it up and the scanner won't even turn on after I plugged it in. Tested pin 16 to chassis ground and only getting .018 Volts
  18. May 6, 2025 at 8:04 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I’m sorry you’re having such a bad time of it I wish I knew the answer.
  19. May 6, 2025 at 8:04 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Check your OBD Fuse (7.5A) in the interior fuse box and see if it has power on both sides, if it doesn't then I'd suspect @Bishop84 is correct and you blew the main 120A J/B ALT fuse.
    t0p_d0g likes this.
