Helper springs intall..yes did searches
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stang951, Sep 14, 2025 at 2:23 PM.
  1. Sep 14, 2025 at 2:23 PM
    Stang951
    Stang951 [OP] Member
    On a trip....pulling motorcycle trailer with 2 bikes, Vagabon XL rooftop tent, loaded down with camping gear. Trip up was ok...but squared pretty good. Thinking of buying some Superior Automotove helper springs for thr trip home. Looks like an easy bolt in install....but need to make sure. In north east Georgia and cant find any Hellwigs or other brands that are in stock up here....
    Is the install simple bolt on? Read some posts that the spring pack "clamp" had to be removed, and some said no.
    Is this something I can do before heading home with a jack and hand tools or should I wait till I get home and just order the larger hellwig helper.
    Don't tow and have all this stuff all the time
    ..maybe twice a year, which is why I'm looking at the helpers.
  2. Sep 14, 2025 at 2:43 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Read up about RAS suspension. You should really get a heavier load leaf pack.
  3. Sep 14, 2025 at 2:49 PM
    Stang951
    When i get back I'll do more intensive research to determine what I'm going to do about long term solutions.
    This is a right now.$70.00 bandaid if its possible.
  4. Sep 14, 2025 at 3:08 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Do you believe your stock setup won't get you home safely?
    gudujarlson and BabyBilly like this.
  5. Sep 14, 2025 at 4:14 PM
    Stang951
    Not necessarily....
  6. Sep 14, 2025 at 6:03 PM
    22trdoraccab
    22trdoraccab Member
    Yesterday
    About 2 wks ago, I installed the RAS system on the rear leafs on my 22 Taco. It took about 2 hrs total. I haven't hauled anything heavy yet but from what I read in my research, they're great for hauling trailers and heavy loads. Good luck
    eurowner likes this.
  7. Sep 14, 2025 at 8:12 PM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    I installed a set of Hellwig helper springs a few years back. Only need to temporarily remove the u bolts to install. The only complication I had is if the truck is on the ground and the spring pack is loaded, a set of c clamps would be helpful to bend the helper springs into place to install the retaining u bolts at either end.
    Palomar Taco likes this.
  8. Sep 15, 2025 at 2:24 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Two motorcycles (dirt bikes?) on a trailer plus a couple other things? I have a hard time imagining your truck is breaking a sweat. Relax.
    BTW, you might be buying the wrong camping gear. My latest collection weighs 10 lbs total.
    What does “squared pretty good” mean?
  9. Sep 15, 2025 at 2:32 PM
    Stang951
    Lol...trucks not sweating pulling, but the squat is noticeable 200lb roof top tent, 3 bins of gear, plus trailer and motorcycles. I'm on a fixed income so I cant get the latest and lightest gear.
    Close to the end of our first leg of the trip I was hearing a chirping noise when first pulling from a stop....got me looking and saw that it could be the rear u joint straining. Got me a little worried. I think I'll be fine going home, definitely looking at the RAS over the Hellwig spring now.
  10. Sep 15, 2025 at 2:37 PM
    gudujarlson
    Minnesota
    You have a 3rd gen Tacoma, a rooftop tent, 2 motorcycles and 2 tons of camping gear. I think you are doing fine financially. Relax and enjoy your trip. Where ya at?
  11. Sep 15, 2025 at 2:56 PM
    Palomar Taco
    Palomar Taco Well-Known Member
    Aaron
    So FL
    '23 Taco SR5 2wd Street Truck
    Put a little grease on your trailer hitch ball & the "chirp" will likely stop.
    gudujarlson likes this.
  12. Sep 15, 2025 at 4:46 PM
    trenchdigger
    trenchdigger Active Member
    southern Ontario Canada
    2020 trd sport, mgm, long bed
    bone stock
    timbrens work good ,bike weighs 853 pounds
  13. Sep 15, 2025 at 4:52 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    A WDH is a much better mid-trip bandaid than helper springs.
    My opinion.
  14. Sep 15, 2025 at 5:06 PM
    Palomar Taco
    Aaron
    So FL
    Weight distribution hitch
