Helper springs???
Discussion in 'Suspension' started by Qumodo, Mar 5, 2014.
  1. Mar 5, 2014 at 8:24 PM
    Qumodo
    Qumodo [OP] Kid Hauler Trail Rig
    Evan
    Colorado Springs
    2013 TRD Offroad
    Inno IN-SU roof rack
    I am looking to prevent the ass of my taco from sagging anytime i load it with gear. i was looking into a Helper spring but wanted to know if they really help and if so which ones should i go with. Also I do not want to lift at all so AAL is out.
  2. Mar 5, 2014 at 8:30 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Could always go with airbags.
  3. Mar 5, 2014 at 8:48 PM
    Qumodo
    Evan
    Colorado Springs
    2013 TRD Offroad
    a bit outta my budget i think
  4. Mar 7, 2014 at 1:11 PM
    redman2006
    redman2006 Active Member
    georgia
    access cab 4wd TRD
    I just added the Hellwig 990 series helper. I am happy with it on mine. I have a 2006 that I bought used that did not have the TSB done on the springs. Since I was told it is too late to have it done, I went this route.
    I carry a 700 lb round bale of hay weekly and noticed significantly less droop. It is a little stiffer ride, but not significantly.
  5. Mar 7, 2014 at 6:07 PM
    Qumodo
    Evan
    Colorado Springs
    2013 TRD Offroad
    awesome to hear. it didnt lift you any did it?
  6. Mar 8, 2014 at 5:02 AM
    redman2006
    georgia
    access cab 4wd TRD
    It might be up a tick, say 1/2 of an inch, but not something that you would notice at a glance.
    I really have not played with the adjustment on it, but I think if you were to tighten the nuts all the way, it would stand it up a little. All I wanted was to be able to carry a load at level a little better. It does do that.
    One thing that was a little odd on the install was turning one of the brackets sideways. I never quite figured out why that was done. You will have to match the one on the other side so that it is not any tighter that the sideways one or you will have a funny lean when you load it.
  7. Mar 8, 2014 at 7:16 AM
    Qumodo
    Evan
    Colorado Springs
    2013 TRD Offroad
    alright thanks for the help Red. i do not want a lift, only to not sag when i carry a load.
  8. Mar 8, 2014 at 9:07 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
  9. Mar 8, 2014 at 12:37 PM
    Qumodo
    Evan
    Colorado Springs
    2013 TRD Offroad
    how much load capacity do they add? and do the cause the rear end to be lifted up?
  10. Mar 8, 2014 at 1:35 PM
    BTO
    California
    I believe as the model number suggests, 550 lbs. Like the other poster said, maybe 1/2 inch at the most when not loaded.
  11. Dec 10, 2016 at 6:57 AM
    Ory69
    Ory69 Member
    2007 Tacoma Sport Access Cab in Speedway Blue
    has the fancy Pioneer stereo - video thingy that I can't figure out
    Hey, Redman. I have an 07 and I had my leaf TSB done just about 6 months ago. I got a notice from the factory and just called the local dealer. They had them in, scheduled me and had it done within a few days. I'm on the west coast.
