Helping a buddy with his Tundra. Any input appreciated.
Discussion in 'Technical Chat' started by Lou Slink, Jun 29, 2015.
  1. Jun 29, 2015 at 12:27 PM
    Lou Slink
    Lou Slink [OP] I like daags...
    Catskill, NY
    2013 TRD OR DCSB
    OME 886's, Total Chaos UCA's, Dakar's, BFG KO2's on Method Race Mesh Wheels, Bunch of All-Pro Goodies, Warn Zeon 10S Winch
    As the title says, I'm trying to help a friend out with his Tundra. He's got a 2014 Double Cab with the 5.7 liter. Mod list - 6" Rough Country lift, 20x12 Fuel Maverick wheels with a -44 offset and 35" Atturo Trail Blade tires. The speed sensor on the driver's side wheel keeps going bad and causing the dash to light up like a Christmas tree. The Low Tire Pressure, Traction Control, ABS lights are lit up solid. 4 Hi and 4 Low lights are flashing on the dash. The ABS kicks in at low speeds, too. He's brought it to a local Toyota dealership to have it looked at. They're blaming it on the spindle from the new lift. My buddy says it has been pulling to the right and has a shaky steering wheel. He's also contacted Rough Country. They say to check the alignment and that's it.
    Has anyone heard of or had this issue before? What do you suggest for his next plan of action? Get a new spindle to start? Any help would be awesome. Thanks for the help in advance!
  2. Jun 30, 2015 at 9:10 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    Put his brodozer back to stock and see if it goes away.
  3. Jul 1, 2015 at 5:33 AM
    Lou Slink
    Catskill, NY
    2013 TRD OR DCSB
    Big help man. Thanks!
  4. Jul 1, 2015 at 5:47 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Well, that's what I was gonna suggest too.
    These wheeler sensors on our tundra trucks will cause all sorts of issues. I know, I broke a wire on my rear axle that goes to the speed sensor. Soldered it back together, disconnected the battery for a bit and all is good.
    Lou Slink[OP] likes this.
  5. Jul 1, 2015 at 5:58 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Sounds like a defective spindle.
  6. Jul 1, 2015 at 6:27 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    Did lift come with new speed sensors or did u reuse factory speed sensors?
  7. Jul 1, 2015 at 6:43 AM
    Lou Slink
    Catskill, NY
    2013 TRD OR DCSB
    He reused the OEM Sensors.
  8. Jul 1, 2015 at 6:49 AM
    loosnut
    jerry
    feasterville pa
    06 dbl cab long bed
    find local shop that has a MODIS scanner (snap-on) It can View wheel speed sensors,if sensors are bad the sensors will read different speeds making the computer think a wheel is slipping/skidding making abs activate.
  9. Jul 1, 2015 at 7:22 AM
    koditten
    Kirk
    Central Michigan
    Bad wheel berring will cause speed sensor issues.
    There have been reports of people running offset spacers on their hubs to cause wheel berrings to go bad.
  10. Jul 1, 2015 at 7:58 AM
    Lou Slink
    Catskill, NY
    2013 TRD OR DCSB
    Thanks a lot guys! I'll let him know to start there.
